Author Topic: info needed on over-run cutoff valve  (Read 18796 times)
Offline Gambit
Re: info needed on over-run cutoff valve
« Reply #20 on: 27 September 2004, 17:01 »
leave it with me and ill have a study tonight. im even wrote Overrun on the back of my hand so i dont forget
Offline Deefadog
  • Mk2 16V (November 89)
« Reply #21 on: 28 September 2004, 07:45 »
Thanks mate, owe you one!
Offline Gambit
« Reply #22 on: 28 September 2004, 09:01 »
there is a control unit behind the dash for it also. to be honest i'd just leave it disconnected if it has sorted out your kangaroo problem
there is a way to test it using a voltmeter if your interested, haynes manual actually details it quite well. that'll tell you if its the control unit or not that is banjo'd
Offline Deefadog
« Reply #23 on: 28 September 2004, 09:21 »
Thanks for checking gambit, I would leave it but I have to get it sorted as the mpg has droped by 10mpg!!!!
Got in the post this morning a used valve from a fellow kind gti member :) I have given it a blow (no comments please) and the valve seems to pop nice, my original one didnto seem to do this but gurgled a bit, so hopwfully i swap em over and it will be fine :) I'll check haynes out and test it, i did know about this but was not sure what setting my multimeter should be on.
Thanks again mate, i'll let you know, it's been a looooong problem :)
Offline Deefadog
« Reply #24 on: 04 October 2004, 12:43 »
I swapped the cut off valve over but it seems the same, so i guess it's the eletrical module behind the dash :)  could not test it propally on the road as I have a really bad short and the electrics are going crazy at the moment, bet it's that module. :)
Offline Deefadog
« Reply #25 on: 12 October 2004, 12:39 »
Anyone got ant info on this module? what's it proper name, how much can it be repaired/overhauled??
« Reply #26 on: 13 October 2004, 11:48 »
Does it have a part code on it mate?  And what year is it?
Offline Deefadog
« Reply #27 on: 13 October 2004, 12:41 »
I have no idea what it looks like :) I think it is located behind the centre console!
As I have replaced the actuall caut-off valve and it has made no difference I have been told it's the module!! :(
tha car is a MK2 16V November 89
Offline Deefadog
« Reply #28 on: 18 October 2004, 12:36 »
bump
Offline Deefadog
« Reply #29 on: 20 October 2004, 12:51 »
Anybody got any pics of this module or can describe what it looks like, and also the location of it.
Thanks, need to sort this out on the weekend
take care
