Cosmetic and bodywork matters
Big bumpers, 90+ spec arches and trim
Topic: Big bumpers, 90+ spec arches and trim (Read 2771 times)
Silky
13 September 2004, 12:24 »
Is this stuff easy to get hold of ?
I've got an 89 16v with the small bumpers and the big trim down the side, is it an easy swap over from one set to the other ?
Phase 2 Peugeot 205 GTI
BMW E36 328i Sport
jimbo
GTI forum regular
Re: Big bumpers, 90+ spec arches and trim
13 September 2004, 12:55 »
bumpers are a piece of wee. very easy to get at scrappy or brand new from gsf or the like. but not too sure about the rubbing strips. got a niggly thought in me head that the fixing holes are different. you could always weld the hole and bond the trim on or something like that ? personally i have a 1990 mk2 and dont have any rubbing strips on it. i think it looks loads better but thats just me. i think it all depends on what sort of look you are after.
aye up me duck!
Silky
13 September 2004, 13:08 »
WIll have to look at local scrappies then (once i've found one) for the bumpers. I'm after the 90+ look as mine is an 89, wanted the smaller side trim and the nice arches and bumpers.
Did any of them come with side skirts ?
BMW E36 328i Sport
Blue MK2
Guest
13 September 2004, 19:25 »
got a mint front bumper for you if your interested. Unpainted. PM sent bruv
Silky
14 September 2004, 09:56 »
Cheer Blue, have seen the PM and will reply.
So does anyone know if the late Mk2 side trim will go straight on once I've taken the early bigger trims off ?
What about arches and bumpers, are they easy to swap over ?
BMW E36 328i Sport
Uku
Here all the time
01 December 2006, 12:12 »
bump , as id like to know the answer to this too
dubslug
Reply #6 on:
02 December 2006, 10:09 »
i did this on a drive and it went on ok, only problem i had was the pre 90 spec strips had dug into the paint work leaving a long white line of primer
1992 pearl grey 8v
83coupe
GTI forum regular
Reply #7 on:
16 December 2006, 13:26 »
im sure the 90 spec side trims sit above(on top of) the swage line, where the older ones sit below it.
90 spec trim
pre 90 spec
if your paints not to bad underneath it I think you should be ok. as said above bumpers and arces are easy enough
Uku
Here all the time
Reply #8 on:
16 December 2006, 20:30 »
no they both sit in the swage line look at the top edge in comparison to the top of the bumper edge on both piccys.
