Author Topic: fault codes help plz  (Read 3089 times)
Offline navmk4gti
« on: 03 September 2009, 20:40 »
checked my car on vag com today and got these...
got 00654,00655,00532...  checked them up on rosstech.. i dont understand the "voltage b+" error (00532)... or where to look for this stuff can sum1 plz post up pics of where i should be lookin on the seats for the airbag light and what voltage b is  :undecided:
also got this error codes which makes sense for why im getting 15mpg  :angry:
00561 adaption limit not reached.. have no idea what this is.. when i do start the car it starts like it on low battery it struggles a bit.. could this code come up becuase of my throttle body is fooked?? changing it on monday..
« Last Edit: 03 September 2009, 20:42 by navmk4gti »
Offline navmk4gti
Re: fault codes help plz
« Reply #1 on: 04 September 2009, 00:46 »
?  :sad:
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #2 on: 04 September 2009, 02:30 »
have a look underneath your seats for the airbag plug comes out from under the carpet  :wink: as for the 'voltage B+' i wouldn't worry about that you get that if you have disconnected the battery at some point just clear that one  :wink:
2000 Mkiv GTi 1.8T AGU
Offline navmk4gti
« Reply #3 on: 04 September 2009, 03:55 »
thanks for reply mate.. will check the airbag plug in morning.. i wll check see if the voltage error code comes up again ... i cleared them but my car does start like its on low battery all the time so will check battery cables and fuses too and alternator..
any ideas on the 00561 mixture adaption error code  :undecided:
Offline mattkh
« Reply #4 on: 04 September 2009, 10:08 »
Hi
Check that the voltage at the battery is more then 13v when the engine is running.
  • "1.8T AGU"
« Last Edit: 04 September 2009, 10:38 by northeast_gti-t »
Offline mac456
« Reply #6 on: 04 September 2009, 11:34 »
looks like its probably your maf.
did you scan in the engine section or eletrics? within the vagcom
Offline navmk4gti
« Reply #7 on: 04 September 2009, 11:48 »
iv got a slpit in the air pipe which comes after the filter box ( i have aftermarket air filter) is this my problem you think guys?? i think its been there for a while as the metal on the side has slit it open and its kinda stuck on it  :sad:
i scanned in "engine" mac456.. havnt really checked other controllers apart from airbag.. think that was pretty dumb of me i should of checked them all and seen if same code comes in another controller .. will do that later on tho car is getting a full valet at the mo its bloody filthy from the body shop..also just found out my bottom valances are a wrong blue so gotta get it back in the garage  :cry:
Offline Adam
« Reply #8 on: 04 September 2009, 11:48 »
You had a bump didnt you? Looks like your seatbelt tensioners have ignited and need replaced.  :sad:
Down Hill From Here.
Offline navmk4gti
« Reply #9 on: 04 September 2009, 11:50 »
yep i did mate.. the airbags never went off tho? how much is it to replace em.. take it it's above £100
