Author Topic: Horn playing up...  (Read 1337 times)
Offline turbo.jon
  • mk4 1.8t agu
Horn playing up...
« on: 03 September 2009, 20:12 »
Hi all done a search could not find a answer
my horn works only when i press really hard and then sometimes it dont work  :cry: any ideas on how to fix it ??????
cheers
jon
Offline Mr_Orange
Re: Horn playing up...
« Reply #1 on: 03 September 2009, 20:14 »
Oo-er    :laugh:
Build thread clicky
Offline ABOO
« Reply #2 on: 03 September 2009, 20:25 »
Should posts about pressing horns hard be allowed before 9pm water-shed :grin:
2001 aum 1.8T
Offline Rhyso
« Reply #3 on: 03 September 2009, 20:27 »
lol
could be the connectors in the wheel
you need to remove the airbag to have a good look
disconnect battery
turn wheel to 90 degrees (might want to do this BEFORE)
use a screwdriver / allen key and put it in the hold on the back of the wheel - you'll feel it with your fingers and release the clip
turn wheel 180 degrees and repeat - this will release the airbag
can't help you any further than that though  :sad:
Offline turbo.jon
  • mk4 1.8t agu
« Reply #4 on: 04 September 2009, 20:07 »
Had a look at me horn problem  :wink: checked all connections and they look ok but one thing when i press the horn button the relay under the dash is clicking which i dont think its meant to any ideas?
cheers
jon
Offline Rhyso
« Reply #5 on: 04 September 2009, 20:11 »
Offline turbo.jon
  • mk4 1.8t agu
« Reply #6 on: 04 September 2009, 21:03 »
faulty fuse??
here's a fuse box guide
No tried fuse so god knows going change relay see if that sorts it before i get some new horns as now i cant even get a beep out of them  :rolleyes:
Offline turbo.jon
  • mk4 1.8t agu
« Reply #7 on: 06 September 2009, 15:31 »
Been had a good look today had go with a volt meter with it on the horn connector and when i press horn im getting a reading so its got be dodgy horns  :laugh:
