Author Topic: Pads and disc change  (Read 853 times)
Offline boyob32
  • 1.8T
« on: 03 September 2009, 18:43 »
Just a quick question, i have changed pads before but never the discs......i have read a few FAQs and i'm ready, however is there anything i need to be careful of??
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Pads and disc change
« Reply #1 on: 03 September 2009, 19:31 »
Jack up then use axel stands, as you may have to use a lot of force to undo those carrier &/or caliper bolts. ;)
Whereabouts in Brum do you live?
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline DarkGti
« Reply #2 on: 03 September 2009, 22:23 »
yea i can vouch for the carrier bolts they are a right pain in the arse to get off! :wink:
Offline boyob32
  • 1.8T
« Reply #3 on: 04 September 2009, 06:17 »
Other side to you mate, Bartley green.
Is it also worth using the copper adhesive on the back of the pads?
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #4 on: 04 September 2009, 10:40 »
yes it is should stop the annoying squeak/squeal when the weathers hot and stops the pad sticking in the calipers also
2000 Mkiv GTi 1.8T AGU
