Author Topic: Clutch feelin really light?  (Read 5612 times)
Offline kane1210
« on: 03 September 2009, 16:16 »
Yea last few days noticed its feelin lighter on the foot? Should i be worried its on its way out?
Offline Teutonic_Tamer
Re: Clutch feelin really light?
« Reply #1 on: 03 September 2009, 21:00 »
How many miles has the car done?  And has the actual 'bite point' changed?
I feel like a homo
Offline kane1210
« Reply #2 on: 03 September 2009, 21:35 »
no i have tested that seems pretty far down . and its on 71000k now........
« Reply #3 on: 03 September 2009, 21:43 »
Change the clutch fluid.  Just bleed it - same as brakes.  Why the lazy feckers at the stealers can't flush the clutch when they do the brake fluid change is beyond me!  :rolleyes:
Should still be fine, providing the clutch hasn't been abused in any way.
I feel like a homo
Offline kane1210
« Reply #4 on: 03 September 2009, 21:45 »
thanks dude will notify garage, service next week anyway........
Offline jaydubveedub
« Reply #5 on: 03 September 2009, 22:24 »
Is there any 'official' recommendation for flushing the clutch fluid? If not, what would you recommend. Mine is 3 yrs old, 45k miles.
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
« Reply #6 on: 03 September 2009, 22:29 »
It should 'officially' be done at the same time the brake fluid change - ie every two years.
I feel like a homo
« Reply #7 on: 03 September 2009, 22:32 »
Thanks, never knew that. Damn, just had the brake fluid done too   :rolleyes:
Will get it done at the next service. Presume the system has the regular VAG brake fluid in it? Is it easy to do in terms of access etc?
« Reply #8 on: 03 September 2009, 22:42 »
Just normal VAG brake fluid - fed from the brake master cylinder resevoir.  If you are doing it yourself, you must ensure you keep the resevoir topped up to the max during bleeding, because the 'pick-up' pipe for the clutch fluid has a much higher point within the resevoir compared to the brake circuits (a standard 'safety' feature on all cars).  The clutch bleed nipple should be visible on the top of the gearbox housing - you might need to remove the engine cover and air intake trunking for easier access.
HTH
I feel like a homo
Offline FamilyDub
« Reply #9 on: 04 September 2009, 09:43 »
D'oh! Me too - brake fluid was done two weeks ago!!  :undecided:
Still, I've got an outstanding A/c recharge to be done. I mean, FFS who actually needs A/c in Glasgow...?  :evil:
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
