Author Topic: can u help??  (Read 6717 times)
Offline dubslug
Re: can u help??
« Reply #30 on: 16 September 2004, 16:49 »
theres a little black box thing under the wiper skuttle, not sure if thats wot u mean??
cheers for your help though  ;D
1992 pearl grey 8v
Offline davidhawkins_78
  • Valver Bad Boy
Re: can u help??
« Reply #31 on: 16 September 2004, 17:05 »
Listen, can you take a few pics of your engine - say divide it in to 4 sections with the air box off so I can compair the 2 cars - your's being H Plate might be different ...
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Re: can u help??
« Reply #32 on: 16 September 2004, 17:11 »
The black box under the scuttle is the control module for the electrinic ignition.
dubslug, is it using a pierburg 2e2 carb or have you put a webber on it?  If its a pierburg it sounds like you have a vac leak somewhere, possibly the 3/4 pint unit is catching the throttle before the engine stalls?  (The big round thing on the left side with a plunger sticking out)
Offline dubslug
Re: can u help??
« Reply #33 on: 16 September 2004, 17:15 »
its got a webber onit, the engines are the same as i have had a g and h reg. i cant do pics as im stupid on computers  :'(. but the engines are exactly the same etc
1992 pearl grey 8v
Re: can u help??
« Reply #34 on: 16 September 2004, 17:43 »
Not sure how the webber handles idle drop, are you using the std airbox?
Offline dubslug
Re: can u help??
« Reply #35 on: 18 September 2004, 11:30 »
yeah thats standard, replaced it a few times hoping it was thar that was broken but no luck,even got the oil breather hose connected to see if that helps but no.
think i got a bad engine lol
1992 pearl grey 8v
