Author Topic: can u help??  (Read 6762 times)
VeeDubGTI16v
Re: can u help??
« Reply #20 on: 14 September 2004, 16:23 »
how reliable and trouble free are they after they have been set up properly?
Offline davidhawkins_78
  • Valver Bad Boy
Re: can u help??
« Reply #21 on: 14 September 2004, 16:29 »
Twin 40's ???
I had no problems at all with the reliablility, but every other weekend they needed a 'tweak', but my friends always ripped the sh*t out of me for it.
They said I had a sixth sense for when I'd lost half a horse power and I'd be out there checking it over. Once they're sorted and providing you buy a good matched pair and good auxiliaries to go with them you should be fine.
Maybe a rolling road once a year unless you're mechanically minded.
Thinking of added some more grunt to your 16v ??
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
VeeDubGTI16v
Re: can u help??
« Reply #22 on: 14 September 2004, 16:33 »
im looking into it ;D  aiming to do something drastic next summer starting with 2.0l 9a and taking it from there
  • Valver Bad Boy
Re: can u help??
« Reply #23 on: 14 September 2004, 16:38 »
Nice one - go for it !!
If you need any advice on the Webers just PM me - VERY knowledgable as I built my last engine from stratch myself ... was like a bottomless pocket money wise, but 150bhp from a 1600cc engine isn't bad !
If you're after big Bhp get 45's - just be prepared for the fuel bill - full tank (?30 in that car) 120 miles !!  8)
Offline dubslug
Re: can u help??
« Reply #24 on: 16 September 2004, 15:44 »
david where abts u from??
1992 pearl grey 8v
  • Valver Bad Boy
Re: can u help??
« Reply #25 on: 16 September 2004, 15:47 »
Down south Brighton way ... any good to you ??
Offline dubslug
Re: can u help??
« Reply #26 on: 16 September 2004, 16:00 »
im up in basingstoke, would be good if u could take a look at engine some time see wot u think, would a leaking head gasket cause the revs to almost die when u stop then shoot back up??
1992 pearl grey 8v
  • Valver Bad Boy
Re: can u help??
« Reply #27 on: 16 September 2004, 16:14 »
I'd not be thinking that straight away - are there any other symptoms to support that ?
If you're ever in my area i'd be happy to help out ...
I'd be checking for whatever control the idle on your carb.
Try a cheat and adjust the throttle cable so it idles a lot higher than normal - see if you still get the problem then, bet you don't ;) It's just a big game of elimination . . . .
Offline dubslug
Re: can u help??
« Reply #28 on: 16 September 2004, 16:25 »
everytime i stop at lights the revs drop down, then shoot back to normal..
1.checked and replaced all air hoses
2.replaced inlet manifold gaskets
3.changed the carb
none of this has helped, could the advance and retard bit in dizzy not be working??
car also has new fuel filter, fuel pump,battery.
its not as bad now im running the 1800 carb though but still does it, specially on cold mornings
1992 pearl grey 8v
  • Valver Bad Boy
Re: can u help??
« Reply #29 on: 16 September 2004, 16:40 »
Hmmmm - could be a number of things ...
I've just got a G Plate 1600 Driver for my old dear - I'll have a butchers at her's and go from there as I'm not that ofay with the specifics of these engines.
There's no ECU or Control module is there? Just sounds sooo similar to the ISV problem on GTI's. I doubt your's will have that part - but there must be an alternative to it in there somewhere.
I'll keep u posted !!
