Author Topic: Any ideas?  (Read 2956 times)
Offline DC
Any ideas?
« on: 17 July 2003, 14:20 »
Hi,  I bought an 1989 8v GTI about a year ago which I love but there are a few things now which need attention.  Before I give my credit card to the local garage can anyone help diagnose these problems?:   :'(
1.  Really bad tapping engine tapping noise until warm
2.  Another strange noise under acceleration (I've been told timing is  out possibly?)
3.  Tinny rattle from underneath car when going over bumps
4.  Outside temp. gauge starts off ok and then works its way down to -     8!!
If possible I would like to work on the car myself but my mechanical skills are limited.  Any ideas on what the problems are would be fantastic.  Cheers...
Offline richandhazel
Re:Any ideas?
« Reply #1 on: 17 July 2003, 16:16 »
1. That tapping will be your hydraulic valve lifters........very common problem. First of all, have you got a genuine VW oil filter fitted? It has a non return valve in it that prevents the oil in the top of the engine returning to the sump. The cheaper filters don't have the NRV, therefore the top of the engine is starved of oil on startup.
If its not that, then you need to use some lifter cleaner to give them a good clean out. 'Justins145bhpMK1' should be able to help you out with this one.........he works for Castrol and seems to know his stuff.
2. That strange noise under acceleration...........does it sound like a tinkling noise that eases if you ease back on the accelerator. If so that'll be pinking/knocking. You could be right it could be the ignition timing needs retarding. However what fuel are you using? If you're using 95RON unleaded, try some SuperUnleaded (97RON) or Shell Optimax (99RON).
3. Sounds like something is loose, you're going to have to get under there and have a look around. Sometimes well worth doing this with the weight of the car on the wheels i.e on ramps, as when you jack the car up the suspension and subframes drop down and the thing thats rattling i.e exhaust, may have larger clearances.
4. You're sensor isn't located correctly and is getting a misreading from airflow passing over it. Not sure where yours should be, but on my Mk1 its located behind the bumper. Yours may be located in the inner wing somewhere?
Hope that helps.........good luck
Offline DC
Re:Any ideas?
« Reply #2 on: 17 July 2003, 17:18 »
Cheers, I'll try all that and see what happens.
