Author Topic: Digital Clock illumination  (Read 2246 times)
Offline werevilla
« on: 12 September 2004, 21:22 »
i have just bought a mk3 16v on an n plate . When driving at night the trip and mile display shines brighter than the digital clock is this normal or is there a bulb located behind the digital clock
mrwotto
Re: Digital Clock illumination
« Reply #1 on: 12 September 2004, 22:07 »
mine is a m reg mk3 16valver and both my lights are the same brightness, not sure as if there is two different bulbs will have a look for you and let you know tommorrow
Paul
Offline mmollart
« Reply #2 on: 14 September 2004, 16:53 »
as far as i can remember, the lights behind the lcd clocks are surface mount led's & are a right pain to change unless your good at soldering & have loads of patience. there are 2 bulbs in the casing of the clocks above the rev/speedo gauge that can be changed from the back, on the outter casing. you should have brightness control aswell, to the left of the headlight switch, have a play with that see if that does the trick
mrwotto
« Reply #3 on: 15 September 2004, 22:03 »
the brightness control shud change both lights tho not them individually
Offline werevilla
« Reply #4 on: 15 September 2004, 22:14 »
thanks sorted it the bulb behind clock had gone replaced it
