Author Topic: Cone air filters  (Read 4884 times)
redcarboy
Cone air filters
« on: 12 September 2004, 18:35 »
I read somewhere today that if you fit a cone air filter to your car you will expirience a loss of power due to the fact it sucks hot air back  in from the engine when it needs to be cold air and people are returning to the old box type filter is this true can't say that i know what do you folks think anyone had any problems? :o
Fielder5757
Re: Cone air filters
« Reply #1 on: 12 September 2004, 23:44 »
Ive got one mounted on the end of my carbaretta (from a vauxhall) Its right behind the grill and a fair way from the block, Its positioned sideways to air flows right through the grill when im moving, This means that the carb can just abstract whatever air it needs without it being forced down and causing carb freeze, That mixed with the twin webber carb thats being fitted next week i should gain some good power.
Its all about where you position it, Its only air, As long as plenty of it is getting to the motor feel free to experement with it, It cant do any damage to your car. The worst that will happen is that you restrict the air flow and the car becomes slower, Untill you change the setup and its back to the way it was  8)
vwsystems
« Reply #2 on: 13 September 2004, 00:24 »
the old box type some do have the manifold pipe connected to them!
most of this is incorrect! if you get your engine hot! and the touch your inlet manifold which the air flows through you will find that it gets pretty hot..... and lets not forget that the inlet is straight above the exhaust manifold!
so even if cold air was getting in by the time it passes throught the inlet its already warm........
and ie no difference!
i have the k&n kit and the only difference i get is when its really cold about 12c or below! thats when the car goes faster! with either filter on a warm day there will not be a noticeable difference!
apart from the k&n being less restrictive!
« Last Edit: 13 September 2004, 00:26 by vwsystems »
Offline jte
« Reply #3 on: 13 September 2004, 10:02 »
If you just replace your airbox with a cone filter the results will be poor due to hot air from the engine, hence the invention of the induction kit.  Basically a tube between the filter and a supply of clean cold air.
A VR6 isn't a way of life, it's just a car.
Fielder5757
« Reply #4 on: 13 September 2004, 10:06 »
Or alternativly do what the honda boys do, Use a AEM long arm kit.
Basically the arm between the block and the Cone filter is longer and positioned downwards to the base of the car, Just above your suspention where the air is coolest.
Offline 1990
  • Mk2 VR6
« Reply #5 on: 13 September 2004, 10:35 »
The airbox connection from the manifold is flap operated and once the engine is up to temp the flap is closed.
I'm not a big fan of cone filters, but if you do fit one your best off making a box to close off the hot engine bay air from your inner wing area.
The air travels through the inlet manifold too fast for it to get heated up.
Cold air is better because its more dense than hot air so effectively you can fit more cold air thasn hot air into the same space.
1990 mk2 VR6 & 1996 mk3 VR6
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #6 on: 13 September 2004, 10:39 »
There's always been loads of controversy over this one ...
Basically there's more chance of contaminating the air with a cone filter unless it's shielded from the heat in some way. BUT yes in ideal conditions you'll see more air flowing, so with the correct fuel levels you will see an increase in bhp - but only 1 or 2 !
The main question is what do you want out this ... just the noise or more performance?
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Fielder5757
« Reply #7 on: 13 September 2004, 10:48 »
You could always get a RAM intake kit  ;) Basically its a tube comming from your motor, Straight to a large scoop thats usally positioned behind a grill or in a bonnit vent, The best way to get cool air, However it has no filter in it, So best used only for the drag strip ;)
redcarboy
« Reply #8 on: 13 September 2004, 12:30 »
Basically i'm still umming on which induction kit to get been quoted ?97 for a hitachi 92-97 at  local performance shop wanting to increase the hp but if this is only gonna up it 1-2 hp hardly seems worth it for a bit of extra growl. :)
Fielder5757
« Reply #9 on: 13 September 2004, 12:41 »
Thats where your going wrong mate, Dont think of it as a performance upgrade, Think of it as a stepping stone. At the moment your car will only get about 1-2BHP with a intake, However when combined with a full exhaust kit, A Exhaust headder, HT leads and racing spark plugs you will of obtained the basic level of performance modifications, From that point your set to start making larger mods to your motor.
If i could recomend one for you it would be the carbonio long arm kit,
http://www.awesome-gti.co.uk/vw%20golfmk3/engine.html
Howeever if you want a cheaper option then try the ram air kit (situated below the carbonio kit on the same page, Both are long arm ram air kits located behind the grills where the cold air is maximised, Located away from the air box, If your worried about heat however, But a foil engine dress up kit from halfords and cover the pipe with the head reflective coating. This way your getting air from below the motor (and as we all know, Heat rises) And the ram air kits are only about ?55 for a 8V and ?63 for a 16V
