Author Topic: HELP BEFORE I BURN IT!!!  (Read 2507 times)
Offline mk3abflad
« on: 01 September 2009, 19:19 »
RIGHT... I have an ongoing problem with the water system on my car. 2000 1.9tdi 115bhp. Losing water after 2-3 days not alot, just enough to set off the level indicator. Top up then fine for another few days. Have done all the usual suspects.
Water pump - Radiator - Expansion bottle & cap - Thermostat - EMTS sensor & seal - Sniffer test ( clear) Even tried a stop leak (wynns)
Im utterly confused, after I did the rad it was fine for 6 weeks, ish, then it reapeared.....
PLEASE HELP...... :sad: :angry: :cry:  :shocked: :sick:
Offline richw911
Re: HELP BEFORE I BURN IT!!!
« Reply #1 on: 01 September 2009, 23:43 »
Head gasket?  :undecided:
Offline old_n07
« Reply #2 on: 15 September 2009, 18:04 »
depending on where it is leaking on a HG then the sniffer might come up negative as there are no gasses comong back into the expansion tank
Neil
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline mk3abflad
« Reply #3 on: 15 September 2009, 22:14 »
This is what i am thinking.
Thanks for input, just trying to rule out everything before pulling head off.
