Author Topic: wobbly gear stick  (Read 17225 times)
Offline navmk4gti
Re: wobbly gear stick
« Reply #20 on: 10 September 2009, 01:52 »
i had a snoop at my gear linkage and stuff today and found the nuts around  it where pretty loose! (jus give the linkage a tug see if it wobbles too).. so i thought lets tighten it  :laugh: ..
did it and the wobblyness has gone down a lot its gone stiffer now way better then before.. it is still a bit wobbly but very minor.. none the less will be changing the bushes as originaly planned on the weekend along with my MAF  :wink:
so try that guys might solve ya probs out without changing anything.. be careful not damage anything tho  :wink:
Offline Mr A
« Reply #21 on: 10 September 2009, 17:49 »
great news, think i might try that.
gunna have a play with them now and spray them first and see.  if you have any chance of puttin a pic up that would be great help bro.
thanks
- 1999 MkIV Golf TDi -
*  Repairs Needed = Faulty Passenger Door Module, VAGCOM set-up, Rear Wiper, Rust Treatment, Rear Wiper Motor, Battery or Glow Plugs, Stubby Aerial,
Offline navmk4gti
« Reply #22 on: 10 September 2009, 20:04 »
will get pics up tomoz for ya in morning  :smiley:
Offline Mr A
« Reply #23 on: 10 September 2009, 21:27 »
thanks bro,
i sprayed the gear linkage, etc... will see if its affected it in the morning,
i also noticed a little bit of oil near the gear linkage thing.
bit odd.
will be taking it to a mechanic friend of my brothers in oldham on friday or saturday to get it checked out.
im praying he tells me its nothing serious.  i have still not paid for this vehicle, as i have the option to return it if the costs to repair it are too much.  I still have to pay for a service and cambelt on top of this issue. (this is minor in comparison)
Hopefully if i keep the golf (which i hope to do) i will clean out the egr valve an the manifold.
Offline navmk4gti
« Reply #24 on: 10 September 2009, 22:48 »
thanks bro,
bit odd.
you sure u wana be fixing a car you aint paid for?   :grin:
is a 1.8t??
Offline Mr A
« Reply #25 on: 11 September 2009, 10:17 »
i aint fixing it yet apart from the white grease (which is a minor), im just gettin it checked out for free, i took the vehicle from a trader friend of mine as a favour, so he allowed me 2 weeks to check it out and decide if i wanna keep it.
i was aware of the gear stiffness, i just want to find out if its going to escalate into a major problem or if its only a minor issue which can be rectified easily.
its a 1.9tdi s (basic model) i wanted a GTTDI(02 onwards), but its just too much missions to find a decent car relying on other people to drive me there, etc.  this vw is on a T-plate (1999) and has done 117000.  full service history with reciepts dating back to 2001.
Offline gaz_marshall
« Reply #26 on: 11 September 2009, 11:36 »
thanks
I have this problem too (surprise surprise) and being no mechanic wondered how you get at the linkage to tighten up any loose bolts?
Many thanks
Gareth
Offline bobreece
« Reply #27 on: 22 September 2009, 07:33 »
anyone manage to get there gears sorted as mine is still not right
Offline navmk4gti
« Reply #28 on: 22 September 2009, 14:01 »
i jus tightened the linkage.. and its a big imporovement still wobbles a bit but not as bad.. im living with it for a while as got other bits and bobs to fix.. you can tighten bolts around the actual gear stick too if you like that might help too..  :wink:
« Last Edit: 22 September 2009, 14:03 by navmk4gti »
Offline chromepro
« Reply #29 on: 06 January 2015, 22:20 »
Considering this post is over 5 years old and having the same problem with not much info on the web as to an exact solution other than upgrage to the newer linkage set up, here is what ive found.
Early 1.8Ts AGU engines used the same linkage set up as the MK 3. This was changed to the later and much more reliable set up in around 2000 i believe. This particular problem is very common in the older (better in my opinion) AGU engine.
Fault symptoms are of the above, wobbly gearshift and finding it hard to select gears especially 1st and 2nd.
In most cases there are only 2 relatively cheap parts you have to replace.
Watch     https://www.youtube.com/watch?v=skdeN-f8bHU       and you should be good to go. All the best.
« Last Edit: 06 January 2015, 22:23 by chromepro »
