Author Topic: Question about braking wobble wobble shake shake!  (Read 2401 times)
Offline saalro
« on: 31 August 2009, 21:12 »
Olla! I recently changed my front brake pads and disks (GSF Parts, cheap stuff, may be relevant, may not). I also drove down a real bad road pretty much made for tractors, lots of stones/ rocks/ hills with rocks and stones, the bottom of the car hitting the floor and steering being thrown all over the place, it wasn't intentional, iphone GPS it rubbish by the way lol...
So basically when i brake now i've started noticing the steering wheel wobbles, could this be tracking related, could it be a screw from the calipers missing and this causing it to judder, could it be cheap parts from GSF...?
Any possible reasons would be appreciated.
Thanksss.
« Last Edit: 31 August 2009, 21:14 by saalro »
Offline danny_p
Re: Question about braking wobble wobble shake shake!
« Reply #1 on: 01 September 2009, 00:29 »
did you clean the hubs up before fitting the new disks
all the VW's have gone bar 1.
Offline saalro
« Reply #2 on: 01 September 2009, 11:34 »
Yup yup!
« Reply #3 on: 01 September 2009, 11:35 »
Loose wheel bolts.
Offline Agreeable Slick
  • Unit
« Reply #4 on: 01 September 2009, 15:20 »
Badly machined discs perhaps. I changed the discs on my old audi 80, and they shook the wheel under breaking. Took them back changed them over, and problem solved.
Offline Len
« Reply #5 on: 01 September 2009, 15:46 »
Warped disc?
Has your car got ABS?
www.sas.org.uk
www.the-ace.org.uk
« Reply #6 on: 01 September 2009, 16:08 »
Wheel balance weight missing or knocked off.
Offline saalro
« Reply #7 on: 05 September 2009, 19:39 »
I was thinking warped disc, but i did run them in?!
Yeah i've got ABS but it's a different type of wobble if that's what you're thinking, this is a wobble i feel through the steering wheel, not a judder through the pedal.
If it was a wheel weight would it the steering wheel not shake at high speeds also?
Offline sharki786
  • GOT BOOST??
« Reply #8 on: 05 September 2009, 20:38 »
I had the same ,i warped my disks i know the wobble your on about just the steering shakes but depends on how hard your braking.
hope that helps
sharki
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline saalro
« Reply #9 on: 07 September 2009, 23:18 »
hope that helps
sharki
Yeah sounds about right!
Is a warped disc an issue, i feel safe driving it?
