Author Topic: Quick question ?  (Read 2566 times)
Offline rakesh27
Quick question ?
« on: 31 August 2009, 20:10 »
Guys,
At the present moment my front right when turning left the driveshaft is rubbing on the arb slightly,i know to get the whiteline 22mm front arbs do i need
Normal
http://www.dpmperformance.co.uk/whiteline-22mm-front-anti-roll-bar-golf-4-14-16-18-18t-19sdi-19tdi-20-23-v5-0797-p-2815.html
or
Adjustable
http://www.dpmperformance.co.uk/whiteline-22mm-front-adjustable-anti-roll-bar-golf-4-14-16-18-18t-19sdi-19tdi-20-23-v5-0797-p-2816.html
I own a VW Golf 1.8T 2000 5dr also whats the labour time to fit them ?
Thanks all.
Offline Steve_PD
Re: Quick question ?
« Reply #1 on: 31 August 2009, 20:29 »
go for the adjustable  :wink:
should be about an hour or so to fit
Offline rakesh27
« Reply #2 on: 31 August 2009, 20:38 »
Steve,
Im thinking i do front this month and get rear next month, would that be ok for a while, also is DPM the cheapest place to get them.
I see balance motorsport do free delivery only thing the offer ends today, will they do something like this again.
Offline Devilz
  • Cruisin is not a crime
« Reply #3 on: 31 August 2009, 20:41 »
Got similar quesion,
I'm looking to get ARB for my 1.8T as well. Do I need front and rear both or any one will do?
Offline Steve_PD
« Reply #4 on: 31 August 2009, 20:41 »
Will be fine until the rear arrives, make sure you get the adjustable one as well :afro:
I got mine from balance motorsport in a deal they done last year, phone them up tomorrow and see what Julian says
Offline Steve_PD
« Reply #5 on: 31 August 2009, 20:42 »
If you upgrade the front do the rear as well
or just have the rear on its own
Offline rakesh27
« Reply #6 on: 31 August 2009, 20:44 »
Cool, ill do that, also from your pic Steve between your tyre and arch do you have a 1cm gap.
Reason im getting the arbs is to eliminate the rubbing and and to go alittle more lower.
Offline Steve_PD
« Reply #7 on: 31 August 2009, 20:45 »
about that gap  :smiley:
Offline rakesh27
« Reply #8 on: 31 August 2009, 20:48 »
I was thinking get the front arb then lower front and rear togeather, so between tyre and arch around .5 gap or less, i just hope when i drive fast around corners i dont want tyre to hit the arch.
then following month get rear arbs. does that sound ok.
Offline Steve_PD
« Reply #9 on: 31 August 2009, 20:50 »
.5 of an inch? or half a mm?
I get know rubbing with 5 people in the car and I can still get over pretty much any speed bump :smiley:
