Author Topic: Fiscon Bluetooth  (Read 12080 times)
Offline p3asa
Re: Fiscon Bluetooth
« Reply #30 on: 04 September 2009, 10:05 »
Hats off to Fiscon, they are now talking about offering a free fitting service if they can get enough bodies.
http://www.golfgtiforum.co.uk/index.php?topic=127988.20
Offline hutch924
« Reply #31 on: 04 September 2009, 14:37 »
fitted mine today was dead easy
top service from fiscon as i had to phone rich as i was being a mong (did not read the instructions properly) when setting up my phone then got ally at volksport in dumbarton to activate it  :smiley: :smiley:
Sad that i have not got my Astra VXR Nurburgring anymore but well happy with my Mk6 GTi, much better car
Offline keelaw
  • It's here!
« Reply #32 on: 05 September 2009, 08:38 »
Good service indeed!
Ah well, I've gone for the factory fit anyway since not that much more and no faffinf required.
Ok you'll have better connectivity, but my phone (nokia) works fine and I can use the "proper" phone button on my steering wheel :)
Mk6 Golf GTI 5dr, DBP, Monza Shadow, Xenons, ACC, RCD510, Park Assist, Camera, Lux pack.... and now bluetooth.... and now DSG!
Offline hutch924
« Reply #33 on: 05 September 2009, 09:36 »
i can use the proper phone button on the steering wheel
Offline keelaw
  • It's here!
« Reply #34 on: 06 September 2009, 22:34 »
with the fiscon?  i thought from another thread that the aftermarket bluetooth kits utilised the OK button on the right only...?
Offline Masher
« Reply #35 on: 18 September 2009, 14:14 »
Guys, where did you fit the mic? searching around the web it seems it can go in the overhead light space, somewhere on the dash by the instrument cluster or on the pillar (RH side of windscreen).
Mine was delivered today and I just want an easy way to fit it with decent mic reception but without wrecking too much trim etc.
I'm looking at the pillar at the side of the windsceen but what about the airbag, is it safe to remove trim there and how do you get the wire around it?
Do you really need to disconnecto the battery to fit it? it seems that all you have to do is disconnect radio plug and reconnect with the Fiscon part?
Could anyone outline their installation in terms of how they routed wiring, where they sited the bits etc?
Mk6 GTI 5dr Black, Lux pack, ACC, Monzas, Cruise, Park Assist, Pussy Magnet, Bullsh1t Detector
Offline p3asa
« Reply #36 on: 18 September 2009, 14:32 »
http://www.golfgtiforum.co.uk/index.php?topic=124452.0
Seems to be up the door pillar.
I've read others say not to disconnect the battery.
Offline LTGTi
« Reply #37 on: 20 September 2009, 16:18 »
Hi guys. Interested in getting this fitted but the compatability list does not mention the Blackberry Curve 8900. Does anyone know if this is compatable with the fiscon system?
Offline Masher
« Reply #38 on: 20 September 2009, 16:43 »
I got the Blackberry 9000 and it works for calls, plays through audio, mutes radio but I am waiting for the stealer to enable phone option so I can access contacts etc on MFD
Offline R32UK
« Reply #39 on: 20 September 2009, 19:11 »
Yep everything works perfectly but you wont get your text messages on the mfd
