Author Topic: leaking injector?  (Read 3063 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
leaking injector?
« on: 30 August 2009, 21:07 »
i've got what looks like a slight oil mark on the inlet manifold under the no.4 injector, is this a sign of the seal needing replacing?
Offline DarkGti
Re: leaking injector?
« Reply #1 on: 30 August 2009, 21:28 »
ive got the same problem, looks wet by each injector!
Offline james2
  • No scammers please.
« Reply #2 on: 30 August 2009, 22:56 »
mines the same on a couple , i was going to change the o-rings on them but cant find was size seals i need to get :sad:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #3 on: 31 August 2009, 00:53 »
more than likely yes as the sealing ring is more than likely deteriorating allowing the leakage your seeing probably best to replace the four then least you know they are all new and fitted at the same time a little unusual for them to leak afaik
2000 Mkiv GTi 1.8T AGU
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 31 August 2009, 10:37 »
I've had the injectors out when I attempted to fit the twin intercooler kit so one of them might not have seated properly again.
I'll have a search through ETKA later and see if I can find a part number for the AGU and AUM seals (they are probably different)
If not I'm sure there is a number in the seals on there at the mo, will just have to get the magnifying glass out  :laugh:
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 31 August 2009, 10:57 »
the seals will probably be different.. the AGU has those awkward bstard injectors that don't fit anything else
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 31 August 2009, 21:05 »
035 906 149 A - injector 'O' rings x 8
058 133 555 – early injector inserts x 4
06B 133 555 C – later injector inserts x 4
« Last Edit: 27 November 2009, 22:19 by Wazzzer »
