Author Topic: clicking noise while turning  (Read 2928 times)
Offline nadlad
  • Building Surveyor MRICS
« on: 29 August 2009, 19:23 »
hi ave noticed on my 83k golf that when i turn left and right i get a creak noise its liek a slow cr cr crc cr noise but it only does it if its a sharp turning i.e if ure turnign out of a junction if its a slow turn i.e roundabout its ok but it does this when i turn left and right any ideas? price parts?
« Last Edit: 29 August 2009, 21:31 by nadlad »
<<<Big Build Thread>>>
Offline Steve_PD
Re: creakign while turning
« Reply #1 on: 29 August 2009, 19:44 »
Front or back  :huh:
Wishbone bushes, Top mounts, rear beam bushes  :undecided:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 29 August 2009, 19:51 »
top mounts for sure. You gonna be doing the work yourself?
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #3 on: 29 August 2009, 19:56 »
I get this exact same problem, and will be keeping an eye on this thread for helpful possible answers for this!  :smiley:
Offline nadlad
« Reply #4 on: 29 August 2009, 21:16 »
top mounts? i dont know about th ework am not that technical, all i know is that this clicking noise happens when i turn usually in first/second gear, my cousin has a similar problem on his car and he says its the cv joint..... so if it is top mounts how big a job is it the noise definaelty comign from the front and maybe driveshaft dunno though  any ideas???
Offline navmk4gti
« Reply #5 on: 29 August 2009, 21:23 »
sounds like cv joint. best take it garage get it ramped up and have a look.
Offline nadlad
« Reply #6 on: 29 August 2009, 21:25 »
any idea how much it wud cost i wud liek a genuine vw one.
and is a cv joitn different to the cv boot because i had that done a few months ago on the drivers side,
also if it were to be the cv joint then why does it click on both left and right i assuem theres two of these on the front so they cant of both gone at the same time?
thanks
« Last Edit: 29 August 2009, 21:27 by nadlad »
Offline Mr_Orange
« Reply #7 on: 29 August 2009, 21:35 »
thanks
Was the old boot split and lost grease?  Could be the CV joint inside was dry and got damaged.  The CV joint can be replaced on its own without replacing the whole driveshaft, not an easy DIY job though.  Seems quite a coincidence?
If it aint the CV I'd suggest a dodgy top-mount bearing?  :undecided:
Build thread clicky
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: clicking noise while turning
« Reply #8 on: 29 August 2009, 21:37 »
now you've edited the description I would say CV joint also
Offline nadlad
« Reply #9 on: 29 August 2009, 21:41 »
the cv boot was split and it lost most its grease this was later changed though,
ok so if it is the cv joint damaged then would it not only do the clicking on one side howcome it does it on both sides does this mean i need to buy 2 outer cv joints...
anyone know what i will need them is this problem completely independent from the cv boot...
