Author Topic: Need some help!!! Or is it normal??  (Read 2457 times)
Offline R32_T
« on: 11 September 2004, 11:26 »
Hi peeps, was just wondering if someone could help me out. I drive a 2001 20V Turbo, engine is standered except for a induction kit.
When I start my car in the mornings, it revs just over 1000 rpm, as its running for around 20 secs or so, I start to hear like a juddering noise from the engine, like its missing or something. It only lasts for around 10 secs, then revs back to normal. (Normal is just under a 1000 rpm, isnt it???)
Could it be something to do with the vacum pipes??
Thanks
2001 20V Turbo        1997 VR6 Highline
"Granny shifting not double clutching like you should"
Offline topher
  • Administrator
  • fully functioning
Re: Need some help!!! Or is it normal??
« Reply #1 on: 11 September 2004, 13:24 »
what kind of induction kit is it ? if that's all that you've changed you've possibly got some gunk on the MAF sensor, clean it up with a bit of carb cleaner.
Offline R32_T
« Reply #2 on: 11 September 2004, 20:06 »
Its a pipercross. Cheers matey, i'll try that
Offline R32_T
« Reply #3 on: 15 October 2004, 17:37 »
Hi peeps
I've cleaned the MAF sensor with a bit of carb cleaner around 4 weeks ago, and i've cleaned it again today because the problem started again in the morning.
What could it be????? :'(
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 15 October 2004, 18:45 »
if cleaning the MAF cured it temporarily.. it could be on its way out, try cleaning the throttle body too
Offline R32_T
« Reply #5 on: 15 October 2004, 19:31 »
Cheers mate, i'll give that a go tomorrow, hopefully its not raining.
Do you think it could be anything else??
thanks
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 15 October 2004, 19:33 »
hard to say... too much to go wrong on modern engines  :-\
its times like this when its handy to know someone with vagcom to check for faults.
Offline R32_T
« Reply #7 on: 15 October 2004, 20:15 »
Cheers anyway, i'll clean the throttle body and see what happends, if still the same, i'll find someone with vagcom and have it checked out.
thanks
