Author Topic: Mk2 suspension on a Mk3  (Read 4661 times)
Offline mickysuperstar
« on: 29 August 2009, 09:54 »
Hey!
I'm lowering my car by 40mm so looking for some coilovers or just uprated shocks/springs.
I've seen quite a few used options for a mk2 which are cheap enough... My question is, if a mk2 suspension setup lowers by 60mm - will it lower by the same amount on a mk3?
Thanks everyone....
Micky
1992 MK2 GTI 8V FOR SALE!
Re: Mk2 suspension on a Mk3
« Reply #1 on: 29 August 2009, 10:02 »
Yes will fit but you need to use mk3 top mounts and spring plates.
Offline Mikester
  • Civic Type R
« Reply #2 on: 29 August 2009, 12:39 »
Also beware of what car they are designed for and the one you are fitting them too.
As they differ depending on the axel weights.
So mk2 suspension on a vr might not be the best bet.
Offline VR6-Joe
« Reply #3 on: 29 August 2009, 12:54 »
If you fit shocks and springs from a Mk2 onto your Mk3 then there might be about 10mm difference because the Mk2's have a different spring rate so are set up for a lighter car, the Mk3 is a heavy car so the springs might not hold the car so well if you get me? Therefore, sitting a little lower than they would on a Mk2..
For example, I fitted 40mm Mk2 lowering springs to my mates Mk3 and measured it afterwards and it had dropped 50mm.
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline Mikester
  • Civic Type R
« Reply #4 on: 29 August 2009, 13:07 »
Basically exactly what i just said.
The different cars have different axel weights.
But that doesnt come into effect when buying hottuning ones, one size fits all with those sh!tters.
Offline VR6-Joe
« Reply #5 on: 29 August 2009, 16:03 »
Technically speaking you were comparing a Mk2 to a Mk3 VR.
Whereas in actual fact, the Mk3 is a heavier car altogether, be it a 1.4/1.6/1.8/1.9D/1.9TD/2.0/2.8
Offline Mikester
  • Civic Type R
« Reply #6 on: 29 August 2009, 23:41 »
No. I was taking the 2 extremes. Good suspension kits list different parts for non gti, gti, and vr6.
Wipe the dick of ur head and stop trying to be clever
Offline VR6-Joe
« Reply #7 on: 30 August 2009, 00:46 »
  :rolleyes:
Offline davero
« Reply #8 on: 30 August 2009, 01:13 »
Get a room yous two.
Offline VR6-Joe
« Reply #9 on: 30 August 2009, 13:50 »
Hey, I didn't say anything!
