Golf mk4
Wazzzer
window goes up then 3/4 back down!
Topic: window goes up then 3/4 back down! (Read 1153 times)
rob__gti
28 August 2009, 21:50 »
my drivers window is playing up, when i press the switch to close the window, once it has closed it then returns to about 3/4 the way down?
is there any way can you 'reset' the window motors?
anyone else had this problem??
Rhyso
Global Moderator
Sir Postalot
Re: window goes up then 3/4 back down!
28 August 2009, 21:55 »
sounds like the glass isn't quite seated properly
you should be able to adjust using your hands
Fire Up The Quattro
rob__gti
28 August 2009, 21:59 »
ok will take a look tomorrow thanks for swift reply
topher
Administrator
Serious forum addict
fully functioning
28 August 2009, 22:00 »
sounds more like it needs recalibrating. Hold your finger on the button and bring it all the way down (not just the one-touch thing!) then do the same to bring it back up. Ignition off/on and it should have remembered where it needs to sit fully closed
rob__gti
29 August 2009, 00:40 »
cheers thats what i meant by 'reset' i had to do it once in my audi.
Louis
GTI forum regular
29 August 2009, 09:14 »
I think if you disconnect the battery and then do what topher said works aswell
rob__gti
Reply #6 on:
29 August 2009, 19:39 »
ok cheers will try it later as original post by topher do not resovle the problem.
Last Edit: 29 August 2009, 19:41 by rob__gti
Golf mk4
Wazzzer
