Author Topic: what remap software  (Read 4356 times)
Offline RTechUK
  • R-TECH OFFICE 01455 617233
 01455 617233
Offline dannydubs
  • mk2 gti,mk3 wagon,mk5gti
Re: what remap software
« Reply #11 on: 30 August 2009, 23:13 »
if there is a problem with dv will it show up on vws computer i had my car checked b4 i bought it and it came back ok.
is it worth puting a after market dump vavle on and will a mk4 18.t one fit
.....the project.........
Offline Teutonic_Tamer
« Reply #12 on: 30 August 2009, 23:25 »
Yes, agreed.  But not every tech at VW stealers are the brightest tools in the box.  They may not actually plug in the 'puter to check!
Forge do make one, but it is firkin expensive, requires servicing, and isn't really any better than a correctly functioning OEM valve.  I dunno about the 1.8 20vT valve fitting, but the best option is to use the 'piston' valve from the Mk6 TSI engine.  :wink:
I feel like a homo
Offline dannydubs
« Reply #13 on: 30 August 2009, 23:36 »
what i dnt want is that dump valve noise you hear on every chav and his impreza
Offline topher
  • Administrator
  • fully functioning
« Reply #14 on: 31 August 2009, 00:07 »
1.8t one won't fit.. completely different design. you only get the chavvy noise if you fit a forge one and then use their spacer
« Reply #15 on: 03 September 2009, 19:46 »
Yeah - don't they call it sommat like an 'atmospheric spacer'?  :undecided:
I feel like a homo
Offline topher
  • Administrator
  • fully functioning
« Reply #16 on: 03 September 2009, 20:15 »
no i think it's definitely called the chav spacer
Offline jaydubveedub
« Reply #17 on: 03 September 2009, 22:27 »
lmfao :grin:
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
« Reply #18 on: 03 September 2009, 22:32 »
lmfao :grin:
Or sometimes called a 'rice spacer'  :grin:
I feel like a homo
