Author Topic: boost problem i think  (Read 3188 times)
Offline wayne_gtiT
« on: 28 August 2009, 16:16 »
my golf only boosts 5psi untill the engines at 90' (full temp) is this normal?
Offline T_J_G
Re: boost problem i think
« Reply #1 on: 28 August 2009, 18:07 »
No it's not normal. sounds like limp mode to me.
Offline spetzdude
  • I Bleed Blue!
« Reply #2 on: 28 August 2009, 18:42 »
you dont realy want to boost anymore then that when your engine is cold  :huh:
Performance mods: Revo stage 2 map, 5 Peice Hose Kit, TIP, evoloution motorsport air filter, N249 by-pass, Forge spliter valve, lowerd 50mm (KW), Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
Cosmetic mods: Tints,De-wiperd the rear, De-badged front grill, Sharan rear badge, Rear spoiler, 4mo rear valance, 4mo front spliter, arero wipers, stubby areial, DOTZ 18" Alloys, Boost guage, Smoothed Bumbers, ECS N75 Vlalve.
BHP: 231
TRQ: 341.3
Offline Steve_PD
« Reply #3 on: 28 August 2009, 18:57 »
thats not limp mode
Offline mac456
« Reply #4 on: 28 August 2009, 19:20 »
as said, you shouldnt be fully boosting anyway until the the engine is at 90.
i always feather my pedal until its upto temp
Offline james2
  • No scammers please.
« Reply #5 on: 28 August 2009, 23:13 »
my car never hits 90 only in traffic.. i took it on a 10 mile run today and it only just came off cold , and i hammer it around , i am going to do the thermosat and see if that sorts it  :undecided:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #6 on: 28 August 2009, 23:31 »
thermostat should sort it  :wink: and then see if you can get it on vag-com
2000 Mkiv GTi 1.8T AGU
Offline james2
« Reply #7 on: 28 August 2009, 23:34 »
my car has no fault codes :cool:
  • "1.8T AGU"
« Reply #8 on: 28 August 2009, 23:36 »
nice one  :wink: will be your stat  :wink: should warm up fairley quick ie heater blowing warm air 2-3 miles from cold
Offline wayne_gtiT
« Reply #9 on: 29 August 2009, 07:34 »
i dont thrash my car when its cold but i know theres a problem,any ideas of a solution to this, its definatley in limp mode till 90 temp, want it fixing before it gets worse, not really clued up on golfs so i dont know where to start
