Author Topic: temperature - 90c  (Read 4719 times)
Offline mac456
temperature - 90c
« on: 27 August 2009, 16:59 »
hi,
have a few q's about the running temperature on these cars.
once my car is upto temperature, sometimes while driving the guage can sit slightly below 90 (almost like the wind is cooling the car) like at 89, 88. is this normal? when im still it will always be at 90.
just want to make sure my car is safe to rev freely
cheers
Offline Khare
  • The bear that khares
Re: temperature - 90c
« Reply #1 on: 27 August 2009, 17:01 »
you're fine, nothing to worry about.
Offline mac456
« Reply #2 on: 27 August 2009, 17:02 »
thanks.
just out of interest how long does it take for your car to heat up?
Offline Khare
« Reply #3 on: 27 August 2009, 17:16 »
depends, if it is at 8am in the winter then around 2 or 3 miles, if it is at noon in a summers day then about a mile or so, that's the water temp, oil takes about 3 or 4 miles to get to running temp.
Offline T_J_G
« Reply #4 on: 27 August 2009, 17:28 »
This is not right you need a new thermostat
Offline Steve_PD
« Reply #5 on: 27 August 2009, 17:41 »
Dont listen to KhareBear he's a mk3 owner so a little slow  :laugh: :wink:
As Tim said new thermostat. the needle should set spot on 90 once up to temperature
Offline T_J_G
« Reply #6 on: 27 August 2009, 17:48 »
See my guide in the maitenance section
Offline Khare
« Reply #7 on: 27 August 2009, 17:50 »
I'm sorry but what if previous owner has fitted a lower temp thermostat?...Thought about that?
90C +/- 2C is normal.  if it varied between 80C and 100C then yes, tehre would be something to worry about!
Offline navmk4gti
« Reply #8 on: 27 August 2009, 17:50 »
i had same prob.. cheap part and easy to fit so nothing to worry about there  :smiley:
Offline richw911
« Reply #9 on: 27 August 2009, 17:55 »
With the correct parts it should sit and stay bang on 90c
« Last Edit: 27 August 2009, 17:57 by richw911 »
