Author Topic: 16v trouble starting, misfire........................  (Read 3012 times)
Offline Diluxe
Re: 16v trouble starting, misfire........................
« Reply #20 on: 28 August 2009, 11:03 »
yep its the one going to the ECU , just rang GSF they do it by the meter for 2.20 pricey compared to ebay , but hey that the way the cookie crumbles, part number 18600 if anyone comes across this thread in the future.
Will update if this isnt the fix.
cheers for your help so far
1997 16V
Offline Len
« Reply #21 on: 28 August 2009, 13:05 »
Good luck! :grin:
I fitted a new pipe to that recently and although it was clear (could blow through it) because it was too small a diameter it caused problems like you have!
www.sas.org.uk
www.the-ace.org.uk
Offline Diluxe
« Reply #22 on: 30 August 2009, 09:52 »
Good luck! :grin:
Do you mean the replacement pipe you bought was of a thinner internal diameter and caused problems, as  the one i've bought and fitted from GSF looks to be slightly smaller, and this morning i've still got the same issues  :cry: Saying that the connectors at the ECU and throttle body cant be more than 2mm in diameter?? Runnin out of ideas..............
I replaced the relays so we count them out.
Update, car wouldnt start, had AA out , the coils nackered, he plugged on in that he had and the car was running smoothly, anyone know were i can get one from over the bank holiday? ECP are supposed top open sundays in wembley but there not picking up, and I dont think GSF open?
Updated new coil has fixed the car, its revs cleanly round to 7k, no misfires & only 26 quid from local motor spares shop  :smiley:
cheers
« Last Edit: 30 August 2009, 16:30 by Diluxe »
1997 16V
