Author Topic: What do i need to make better drive ?  (Read 1249 times)
Offline rakesh27
« on: 27 August 2009, 12:03 »
Guys,
I wanna get
1) Bushes (for which part)
2) Dogbone bush - i know this helps traction
3) droplinks - Does this mean i can lower the front more since the driveshaft wont rub on arb, what about rear since i want to lower as well.
Thanks - i need advice, thanks
Offline Steve_PD
Re: What do i need to make better drive ?
« Reply #1 on: 27 August 2009, 13:45 »
vRS rear beam bushes
Rear ARB  :wink:
Offline rakesh27
« Reply #2 on: 27 August 2009, 13:52 »
Steve,
I really didnt want spend lots,
If i was gonna replace the front bushes which ones do i need for better firmer ride and steering response, also am i correct on the droplinks.
Offline Rhyso
« Reply #3 on: 27 August 2009, 13:52 »
Rear ARB  :wink:
new engine mounts - might as well for for the full THS engine mounting system as that includes a new dogbone mount
Audi TT rear wishbone bushes (front wishbone but the rear bush) plus what Steve has put
Offline Rhyso
« Reply #4 on: 27 August 2009, 13:53 »
Steve,
vRS bushes are £30
Rear ARB is £150 approx
to get a MKIV to handle decently you've got to be prepared to spend a few quid
Offline Steve_PD
« Reply #5 on: 27 August 2009, 13:56 »
if you dont want to spend loads go for the ARB, that will make the biggest difference  :wink:
Offline rakesh27
« Reply #6 on: 27 August 2009, 14:12 »
Would i need front (Obvously) and rears to make more tighter feel, and what about doplinks, would that able me to lower the front alittle more.
I ask this cos ive already got JOM coilovers fitted and lowered pretty good, but if i go to low my front right tyre when turning left rubs driveshaft rubbing on arbs. I would like to lower front and rear.
My JOM have a range 20mm-110mm
