Golf mk1
Caddy loosing water, help needed!!
Topic: Caddy loosing water, help needed!! (Read 1444 times)
t111bul
27 August 2009, 11:59 »
Hi guys,
My friend has recently bought a 1986 1.6 Caddy that keeps loosing water. There doesn't seem to be any leaks, inside and out but the water is just dissappearing! Can anyone help with any ideas?
Thanks in advance
Tim
raferackstraw
Re: Caddy loosing water, help needed!!
27 August 2009, 16:10 »
check for white smoke from exhaust and look for sign of oil in coolant or coolant in oil
if your getting any of above its head gasket
if there are no obvious external leaks then it is pointing towards head gasket, get a compression test done on all cylinders
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
caddyrage
GTI forum regular
28 August 2009, 17:00 »
Try looking at the 2 pipes going into the heater matrix, next to the servo. 1 has a valve on it which opens when you turn your heating on. That valve tends to leak.
btw, is it diesel or petrol?
03 ibiza PD 130 sport, smiles per miles!
83 mk1 golf gti, 16v 2L PL
92 mk1 caddy, now stripped for resto
WWW.FENDUBBERS.CO.UK
cambridgeshire vw owners club
Golf mk1
