Author Topic: VR6_ROB's MK2 VR  (Read 85549 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
Re: VR6_ROB's MK2 VR
« Reply #50 on: 29 June 2010, 00:17 »
how have you secured the mk3 dash clocks into place?
I unscrewed the brackets and moved them along then i just used cable ties put them through the
holes on the clocks and round the brackets positioned them infront of the bracket rather then in it
sits closer to the dash then
Offline SoundillusioN
« Reply #51 on: 29 June 2010, 09:11 »
ha, did same as you when i rewired mine, forgot the heater controls..... looking good, its not far off now then!
annoying aint it i tried everything to get it to fit without taking the dash back out but it was not having it
still a way to go yet lucky if i get 1 hour a week on it
yeah i'm the same, just dont get time but the missus is putting pressure on to finish as she doesn't like it looking sorry for itself outside the house...  I still think i might to get the dash out again soon as i think i have missed a couple of things.
Offline cняis
« Reply #52 on: 29 June 2010, 21:35 »
pretty much as ive done mine, but with the mk3 clocks being bigger than the mk2 originals you struggle to see the temp/fuel gauges, indicator/full beam warning lights and the row of warning lights at the bottom of the clocks  :grin:
i wonder if corrado clocks fit better?
Offline VR6_ROB
« Reply #53 on: 30 June 2010, 19:04 »
i thought corrado clocks were even bigger
Offline cняis
« Reply #54 on: 30 June 2010, 22:23 »
theyre not as tall as mk3 clocks but would have to double check the width
Offline VR6_ROB
« Reply #55 on: 25 July 2010, 16:53 »
the golf has now gone
Offline dom
  • Back in a Mk4
« Reply #56 on: 25 July 2010, 17:44 »
Gone? How come??
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
« Reply #57 on: 25 July 2010, 22:03 »
What? Why?  :huh:
Keeping schtum. Mostly.
jamrock
« Reply #58 on: 25 July 2010, 22:25 »
 :cry: :cry: :shocked:
Offline VR6_ROB
« Reply #59 on: 26 July 2010, 19:13 »
its away getting the wiring chopped and fed through different places so it cant be seen
then off to the bodyshop to get the front end sorted out :grin:
