Hey everyone,
I've got a few problems with my 93 obd1 VR6, can someone please help.
I've had it a couple of weeks now, and its been sitting on the driveway, waiting while I sell my GTi.
It's taking for what seems forever to heat up!! After about 10 mins at Idle the oil temp is at 68 and the coolant temp gauge on the dash has barely even moved. Its at this point the reservoir tank starts to overflow. Also if I turn the engine off, then restart, the coolant temp doesn't move back to where it was before I turned it off. Not straight away anyway.
Feeling the coolant pipes, the top rad hose is very hot but the bottom rad hose is only warm.
Its also idling at about 600 rpm after about 5 mins of running.
I have searched on here for a possible solution, and to my horror found this could be a head gasket failure.
Theirs no oil in water, or vice versa that I can see.
I've also changed the reservoir tank cap for a blue one which I got from the scrapie. When the coolant started to overflow, I turned the engine off and unscrewed the reservoir tank cap and there was no pressure change, it just unscrewed with no effort.
Can someone please please help
