Author Topic: Remap - standard N75C/F, J or H???  (Read 3411 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« on: 26 August 2009, 21:12 »
I've currently got an H valve on my AGU but after fitting the K03s I keep hitting what seems to be the overboost cut out...
Now I'm thinking this must be the N75H as it's also fitted in reverse. What valves do you lot have on your remapped Golfs? Especially AGU's with the R-Tech map  :wink:
Offline DarkGti
Re: Remap - standard N75C/F, J or H???
« Reply #1 on: 26 August 2009, 21:22 »
n75c valve works fine, boosts just over at 1.5bar thats remapped AGU ko3s!
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 26 August 2009, 21:36 »
go with the standard item, and fit it the right way round.. that is what the bench flashed map will be expecting to see :wink:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #3 on: 26 August 2009, 21:44 »
+1
I've tried 3 out if the 4 N75's on the AGU-S, & C was (by far) the best.  The only other one which maybe as good or better is the F, as that superceded the C.  :afro:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 26 August 2009, 21:54 »
toph you have answered my next question  :smiley:
ok then, wanted: N75C or F!
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #5 on: 26 August 2009, 22:36 »
I have always wanted to do back to back dyno tests with ALL the N75 valves on a stock engine and tuned engine.   Are there any members with Valves I could borrow for a few days while we carry out the test?
Nick
 01455 617233
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 26 August 2009, 22:48 »
If I get hold of a C or F valve by the time I send you my ECU I'll put the H in there with it :wink:
Offline andy_airsoft
« Reply #7 on: 27 August 2009, 09:02 »
This is pretty much the same post I was going to do this morning but with an AUM instead.
Toph do you reckon a C or F would be ok on a remaped AUM?
2001 1.8T GTI, AUM, R-Tech Stage 1 Remap, 18" Nouvolari alloys with 6mm spacers, Green Cotton panel filter, N249 Bypass, Drilled airbox, Forge 007p, Original R32 headlights (FOR SALE, PM ME WITH AN OFFER), full leather, New N75F, New MAF, New Coilpacks, Sprayed black interior (Woo Hoo not more wood), Indigo Blue
Offline topher
  • Administrator
  • fully functioning
« Reply #8 on: 27 August 2009, 09:47 »
the C or F will do fine, it's just the J's i'm not keen on... but maybe with a little more map development, who knows!
« Reply #9 on: 27 August 2009, 10:51 »
Well I just went to VW and got 2 coil packs, 1 MAF and a N75F as I was told the C is no longer stocked by them.
Just put the N75F in and now my car hold a good 9psi but will see what its like later as it does have a mind of its own.
Will be putting the coils in later when the engine cools down and the MAF will be in stock tomorrow morning.
Really hope this sorts out my boosting problem as thats just cost be over £200  :cry:
