Author Topic: Idle problems...  (Read 2331 times)
Offline Trickyboy
  • MK5 GTi 3dr Reflex Silver
Idle problems...
« on: 26 August 2009, 18:40 »
Have noticed a barely noticeable lump in the idling on my mk5 gti, used to get it in the mk4 also, hard to explain, like an almost unnoticeable shake, can only really feel it through the drivers seat when stationary... Is this normal? Ta!
Offline jaydubveedub
Re: Idle problems...
« Reply #1 on: 26 August 2009, 20:07 »
Is it like a very (very very) small jolt that you feel through your backside through the seat? Almost as if the engine is coughing ever so slightly? If so, mine does that sometimes but it is hardly noticeable.
My old Passat used to do that to, and my Fabia before that.
I wouldn't think it's anything to worry about.
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
Offline Trickyboy
« Reply #2 on: 26 August 2009, 22:50 »
Yeah, pretty close, just now and again, not all the time. Though it was missing slightly?
Offline Sweeney
« Reply #3 on: 27 August 2009, 19:07 »
Have noticed this for the past wee while in my Ed30 (dsg). Sitting with it in D it doesn't do it (i'm assuming the clutch being enagaged at some level is cancelling it out), however if you knock it into P or N and sit idle on tick over it does it. Whether it be from a cold start, after hooning, regular driving, even giving a wee tap of the throttle doesn't affect.
My friends Bora TDI had a misfire issue and it was a fairly noticable shudder whereas this is like a wee gust of wind catching the car sort of feeling.
Offline ub7rm
« Reply #4 on: 27 August 2009, 21:19 »
I have this as well, very slight and the revs dont twitch at all.  I think its normal, there was a discussion about this a while ago and most people were reporting the same thing...
2020 BMW 128ti
2017 Golf GTD Estate
Offline Trickyboy
« Reply #5 on: 28 August 2009, 13:15 »
Seems that it must be a normal occurence then, thanks for the replies chaps.  :smiley:
Offline FamilyDub
« Reply #6 on: 28 August 2009, 15:23 »
Welcome!  :cool:
Just start sh*tting yourself if the revs move up and down..... like mine  :embarassed:
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
Offline mac456
« Reply #7 on: 28 August 2009, 19:25 »
my mk4 does this as well
