Author Topic: What exactly does this mean?!  (Read 2698 times)
Offline brett30
« on: 10 September 2004, 02:22 »
Hi,
Just cleaned out the throttle body on my car, and since then the idle speed has been around 1500-2000 rpm. When I first start the car its fine, but after that it runs bad.
Carried out TBA using VAG-COM under group 098, but it has created the above problem.
Under the fault codes I get the following message:
Control Module Part Number: 06A 906 019 AK
Component and/or Version: 1.6l 2V/R4 SIMOS HS2554
Software Coding: 04000
Work Shop Code: WSC 00028
1 Faults Found:
00533 - Idle Speed Regulation
19-00 - Lower Limit
Can any body please help!!!!?
Thanks
Brett.
