Golf mk4
Wazzzer
Slight knocking over small bumps..
Topic: Slight knocking over small bumps.. (Read 1910 times)
xpeterpx
25 August 2009, 18:45 »
I hope someone can advise me..
I've detected a slight knocking noise coming from the from wheels but I can seem to find where its coming from.It doesn't happen when I rock the car and I had the suspension shocks changed about 6 months ago.Seems to only be noticable when going over small bumps.
I'm thinking possibly wishbones?
Cheers as usual
pete
richw911
10k hero
The Linkmeister and an OEM Freak.
Re: Slight knocking over small bumps..
25 August 2009, 18:46 »
Wishbone or ARB bushes
AudiA8Quattro
Forum addict
25 August 2009, 18:55 »
Sounds like an anti roll bar drop link.
xpeterpx
Cheers...an expensive fix?
AudiA8Quattro
Forum addict
25 August 2009, 18:57 »
No. Shouldn't cost more than £50ish fitted.
Thats for one side, probably best to do both.
I could be wrong though, not sure how much the links cost on a mk4.
Simple to fit.
xpeterpx
25 August 2009, 20:06 »
Many thanks again..
I dont suppose anyone knows if I need 21mm or 23mm -apparently theres 2 sizes.
My cars a 2000 Mk4 Bora by the way
Pete
jake
Reply #6 on:
25 August 2009, 22:57 »
sounds to me like it could be your bushes!
Mine did it, starts off not too bad then gets worse over time!
bobbarley
Serious forum addict
I'm kind of a big deal...
Reply #7 on:
25 August 2009, 23:07 »
Mine was knocking, turned out the bolt had fallen off the ARB drop link!! £10 for a new one, then fit it yourself.
GJSEB79
Reply #8 on:
26 August 2009, 12:45 »
this is exactly how mine started wasnt to bad then got really bad over time had to have rear bushes one. it sometimes not a cheap fix drop my rear axle my self cleaned all down repainted it then got my mate to press the rear bushes in as i didnt fancy hammering them in i got the olds ones out with a little bit of heat an chisle. looks wicked now thought alot smoother ride still got a little bit bumpy ride but i put that down to the 18 inch wheels it cost me in total 40 quid to have the bushes pressed in cheers
Golf mk4
Wazzzer
