Author Topic: apex springs  (Read 2618 times)
Offline jtomlin
  • 1999 AGU 1.8T GTI
apex springs
« on: 25 August 2009, 16:40 »
hi
found these springs, theyre the only i can find that lower it by 50mm, will they be good enough? anyone had any experience? reccomend another brand? can i run these on standard shocks?
thanks
http://cgi.ebay.co.uk/Apex-Lowering-Springs-Golf-Mk-4-4cyl-X-LOW-50mm-97-03_W0QQitemZ250486445027QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item3a5227d3e3&_trksid=p3286.c0.m14
Offline AlanD
  • MK5 2.0T 16v
Re: apex springs
« Reply #1 on: 25 August 2009, 16:41 »
From my limited knowledge on this subject anything over 40mm and you will also need new dampers. Could someone confirm?
Offline Rhyso
Re: apex springs
« Reply #2 on: 25 August 2009, 16:43 »
thats you're best bet as the standard shocks will run out of talent very quickly indeed
why not go for the JOM Spring & Shock combo for a 40mm drop or are you dead set on a 50mm drop in which case you should go for coilovers
Re: apex springs
« Reply #3 on: 25 August 2009, 16:45 »
+1 always best to fit new shocks with lowering springs.
Offline jtomlin
  • 1999 AGU 1.8T GTI
Re: apex springs
« Reply #4 on: 25 August 2009, 16:48 »
its just im not sure if 40mm will be low enough which is why i was looking at 50, looks like for the extra 10mm it will be a tad expensive :(
Re: apex springs
« Reply #5 on: 25 August 2009, 16:49 »
Why not go for coilovers
Offline barry-gti
Re: apex springs
« Reply #6 on: 25 August 2009, 16:49 »
i was thinking of getting the APEX 45mm Springs and shocks kit. but so many people are talking about the JOM kit. is it actually good because i dont really like/trust JOM stuff
Offline AlanD
  • MK5 2.0T 16v
Re: apex springs
« Reply #7 on: 25 August 2009, 16:49 »
Even with 40mm your pushing you luck, and has Rhyso said, they will soon die on you if you JUST add the lower springs to your standard dampers.
VERY sound idea if you ask me.
Im guessing wonga $$$$$$$$$$$ ???
Offline jtomlin
  • 1999 AGU 1.8T GTI
Re: apex springs
« Reply #8 on: 25 August 2009, 16:50 »
big bucks!
Offline Rhyso
Re: apex springs
« Reply #9 on: 25 August 2009, 16:54 »
big bucks!
£400 for a set of Weitecs??
Buy cheap - buy twice
i'd save a few more quid and do it properly
