Author Topic: couple of questions  (Read 6021 times)
Offline bobreece
couple of questions
« on: 25 August 2009, 16:06 »
does cruise control save fuel and is it worth it?
how do i tell if my 150 tdi has the sports suspension as standard fitted?
Offline AlanD
  • MK5 2.0T 16v
Re: couple of questions
« Reply #1 on: 25 August 2009, 16:07 »
Cruise "should" save you fuel, but knowing how to drive a car economically can also do the job just as well, if not better.
Your 150 will have the same set-up as the 1.8T ;)
Offline Steve_PD
« Reply #2 on: 25 August 2009, 16:09 »
I found that driving carefully got me more mpg than when I had cruise control on
and yes the tdi150 has the sports suspension  :smiley:
Offline Rhyso
« Reply #3 on: 25 August 2009, 16:10 »
have to agree with Alan (starting to become a regular occurance  :undecided:)
Cruise i guess is a nice feature to have but i've never gotten on with it.  Set your trip comupter to show instant MPG and play around with the throttle - that will give you a good idea of what can be achieved
Offline bobreece
« Reply #4 on: 25 August 2009, 16:12 »
but how do i tell can i look under at the suspension and it will have certain markings or something?
can drive well but i do 140 miles 3 times a week
Offline Rhyso
« Reply #5 on: 25 August 2009, 16:13 »
park it next to a standard NON GTI Golf - thats how you tell  :laugh: :laugh:
Springs have colour codes on them - most likely scrubbed off depending on mileage mind
Offline AlanD
  • MK5 2.0T 16v
« Reply #6 on: 25 August 2009, 16:14 »
Well put it this way, they came with the 1.8Ts Sports setup out the factory. Why someone would take them out and put the lesser ones on makes no sense. They may have replaced with with an aftermarket setup which will give a slightly harsher ride (depending on what went in) but this will improve handling and reduce bodyroll etc etc over the Sports setup.
Offline bobreece
« Reply #7 on: 25 August 2009, 16:24 »
mileage is only 52000
Offline Rhyso
« Reply #8 on: 25 August 2009, 16:26 »
could have been driven through a hedge backwards or not washed since it was bought  :tongue:
if you're getting under the car try and check near the top of the springs as they are prone to rusting and snapping!! My passenger side spring did this and when i had the springs changed my drivers side was going the same way......
Offline bobreece
« Reply #9 on: 25 August 2009, 18:04 »
look good to me they have a blue circle on them like a big dot?
