Author Topic: how do i unplug my airflow meter?  (Read 788 times)
Offline chally
« on: 25 August 2009, 13:44 »
Hello
I have an 8v gti which has a bit of a misfire around 2500rpm. I've replaced plugs and leads and after reading several similar posts on here my next guess is airflow meter. I want to unplug it and see if it drives ok without it. How do i unplug it without breaking anything (nails included  :laugh:)? I have a tendancy for being a little heavy-handed..... Any tricks/tips would be greatly appreciated.
Many thanks
Chally.
Offline Adam
Re: how do i unplug my airflow meter?
« Reply #1 on: 25 August 2009, 14:42 »
You take the plug out of the sensor....simple.
Down Hill From Here.
gtigolfthree
« Reply #2 on: 25 August 2009, 18:44 »
+1 its a little black box between the airbox and the throttle body and  you may wish to give the throttle body a clean while your at it usually helps.
