Author Topic: radiator help needed.....please  (Read 1722 times)
Offline yorkshire_gti
« on: 25 August 2009, 12:53 »
I need to replace the temp sensor on my radiator and was wondering where
to get one from online...
is it called the radiator temp sensor or something else?   :lipsrsealed:
Its a 1.8 mk3 golf..it has 3 pins
If somebody could give me a link to one would be great  :)
« Last Edit: 25 August 2009, 17:05 by yorkshire_gti »
Re: radiator temp sensor...
« Reply #1 on: 25 August 2009, 12:54 »
GSF or Euro car parts should be able to supply one.
Offline Khare
  • The bear that khares
« Reply #2 on: 25 August 2009, 13:58 »
it's called the fan switch. It's what turns the fan on when temperature reaches 94C I think.
GSF do them as wayne said.
« Reply #3 on: 25 August 2009, 14:27 »
thanks...
GSF have a...
93479  RADIATOR THERMO SWITCH    G3 3 Pin with Offset Pins    8.50
i guess it is this?
« Last Edit: 25 August 2009, 14:32 by yorkshire_gti »
« Reply #4 on: 25 August 2009, 16:15 »
until i get this sorted is it safe just to stick the fan on a switch so the car
does not overheat and i can turn the fan on manually?
Offline Paul86S2
« Reply #5 on: 25 August 2009, 16:46 »
You can run a live lead from the battery positve terminal to a switch and then from the switch to the fast fan pin in the fan.
Then turn it on if your temp starts to go above normal.
Paul
PS Make sure you use suitable sized wire and switch.
« Reply #6 on: 25 August 2009, 16:58 »
thanks...
can i bridge the connections on the radiator plug and leave them bridged so the fan will
come on automatically with the ignition?
Offline Khare
Re: radiator help needed.....please
« Reply #7 on: 25 August 2009, 19:49 »
thanks...
GSF have a...
i guess it is this?
that's it.
Don't bother having a manual fan switch, why? just means you have to do it manually........Just get a new switch and then it will do it automatically spot on  :smiley:
« Reply #8 on: 25 August 2009, 19:57 »
thanks....
the manual switch was just something to keep me going until i get the replacement part...
Offline Paul86S2
« Reply #9 on: 25 August 2009, 21:38 »
thanks...
you really don't want it running all the time
Paul
