Author Topic: oil change?  (Read 1257 times)
Offline gtiscott
oil change?
« on: 24 August 2009, 15:58 »
Hi guys, I want to do an oil change myself but never done one before, how easy/hard is it for a complete novice? and does the car need to be jacked up?
cheers
Scott
Offline JamesBaby
Re: oil change?
« Reply #1 on: 24 August 2009, 16:38 »
It's easy mate. The only issues that you may come across (but they are easily solved) is that the oil filter may be on tight. No problem if you have a strap wrench tho, or just stab a long screwdriver through it worse case. Although the latter is messy.
The car has to be jacked up for access to the draining nut on the sump. Unscrew it and let the oil out into a suitable container. Then remove the oil filter. Use a new washer on the sump plug.
add about 3.5 litres of oil and then start the car and let it get warm. Then once cold again, top up as neccesary. Do not overfill.
Offline VR6_Wherry
Re: oil change?
« Reply #2 on: 24 August 2009, 16:43 »
+1  :laugh:
Offline robz
Re: oil change?
« Reply #3 on: 24 August 2009, 16:48 »
^^ +2
dead easy
(dont over tighten the new filter though, hand tight) :)
Offline gtiscott
Re: oil change?
« Reply #4 on: 24 August 2009, 19:26 »
thanks guys, its the jacking up part i am not comfortable with as i am never sure where to put the jack :embarassed:
scott
Offline bored_Welsh_lad
Re: oil change?
« Reply #5 on: 24 August 2009, 19:28 »
trolley jack or suicide jack?
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline gtiscott
Re: oil change?
« Reply #6 on: 24 August 2009, 19:33 »
trolly jack :smiley:
Offline andc1
Re: oil change?
« Reply #7 on: 24 August 2009, 21:12 »
get the car hot first so the oil is thin!!!!
Re: oil change?
« Reply #8 on: 25 August 2009, 09:59 »
^^As above, much better to warm it 1st but not too hot or it will burn you.
Offline MK3GTI_16Valve
Re: oil change?
« Reply #9 on: 25 August 2009, 11:05 »
my oil filter always seems to be baked on, wrapped a belt around it the last time to get it off, worked a treat
