Golf mk2
New Performance Exhaust Manifold
Topic: New Performance Exhaust Manifold (Read 3475 times)
Judderi
Guest
09 September 2004, 14:16 »
Just got in my car at lunch and it sounds terrible. I think the manifold needs replacing. Anybody recomend anywhere for performance manifolds? Its a 16v with a 2.0 conversion engine.
Last Edit: 09 September 2004, 14:30 by Mk2GTI2.016v
davidhawkins_78
Valver Bad Boy
Re: New Performance Manifold
09 September 2004, 14:19 »
Why you think it's the manifold ??
As for performance one's there's nothing wrong with the Veedub item - but there are different variations you can get for more performance, I think a 50mm inlet is the one most people step up to.
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Judderi
Guest
09 September 2004, 14:27 »
I mean the exhaust manifold not the inlet manifold.
VeeDubGTI16v
Guest
09 September 2004, 14:30 »
the standard exhaust manifold is pretty damn good for a standard one too
why dont you have a look at the manifold first before you spend money, they can usually be welded back up
davidhawkins_78
Valver Bad Boy
Re: New Performance Exhaust Manifold
09 September 2004, 14:41 »
Whoops !!! Got inlet manifolds on the brain today ...
As veedubgti16v says see what the damage is first - could just be a gasket or even a fooked heat sheat making some funky noises.
Aftermarket manifolds do flow better - but I've heard you really have to run uprated engine mounts or risk them cracking. PLus they never have the right fittings and I can't stand bodges !!!
vwsystems
Guest
09 September 2004, 15:28 »
tsr sell the manifolds. try them.....
tsr performance
they list the prices on the website..... they do them for uprated engines.
Veedubgt18v
Guest
Reply #6 on:
09 September 2004, 17:50 »
tubular manifolds are sexier tho!
VeeDubGTI16v
Guest
Reply #7 on:
11 September 2004, 09:07 »
if you want a new manifold without doing engine mounts etc then get a mild steel one. it wont put stress on everything its joined to like a stainless one. and get it all heat wrapped too
Andy Mc
GTI forum regular
Reply #8 on:
11 September 2004, 10:17 »
I've recently fitted a TSR stainless manifold to my 1.8 16v, is this likely to put the exisitng engine mounts under any more stress then what the old manifold would have done.....??
(I did change the front one with like for like about 2 years ago)
'90 16v
Judderi
Guest
Reply #9 on:
13 September 2004, 10:42 »
Found out that its actually the downpipe thats gone.
Golf mk2
