Author Topic: 1.8T mk4 downpipe on my mk3 TDI??  (Read 3161 times)
Offline MK3TDi1996
« on: 23 August 2009, 15:58 »
Read somewhere that you can use the above de-cat downpipe on my '96 AHU TDi - This right?
Shouldn't I just use a mk3 decat pipe?
Also, is my exhaust set up on the diesel similar to an 8v/16v set up?
Thanks
Re: 1.8T mk4 downpipe on my mk3 TDI??
« Reply #1 on: 23 August 2009, 16:35 »
Don't see it fitting to be honest, back box will be the same rest of system will / may be different.
Offline Adam
« Reply #2 on: 23 August 2009, 17:54 »
Cat back your system is the same as the VR/16v system
Down Hill From Here.
Offline MK3TDi1996
« Reply #3 on: 23 August 2009, 20:27 »
Okay so I can use a VR6/16v performance exhaust system from the cat back?  Then use a vr6/16v decat pipe for the front? What about any possible manifold options?
Thanks
« Reply #4 on: 23 August 2009, 21:33 »
Thanks
No point in changing the manifold as it is the downpipe that will cause the most issues.
Offline MK3TDi1996
« Reply #5 on: 24 August 2009, 08:24 »
so there's no 4-branch type option?
what is the downpipe upgrade? wider pipe, decat or both?
« Reply #6 on: 24 August 2009, 08:49 »
The manifold on yours is a different set up as it is a short unit with the turbo bolted to it.
Offline MK3TDi1996
« Reply #7 on: 24 August 2009, 08:52 »
so basically no upgrade options then :)
« Reply #8 on: 24 August 2009, 08:53 »
Not sure, but have a good look around and see if you can get a better downpipe that will help.
« Reply #9 on: 24 August 2009, 08:54 »
