Golf mk4
Wazzzer
Performance issue
Topic: Performance issue (Read 2351 times)
J6BXR
Performance issue
22 August 2009, 22:50 »
Have a std 1.8t 150(arz) seems fine round about the town, sounds great ,drives great until you want to go over 3500 then its as flat as a witches T** and ideas? no weird noises from engine ,turbo etc .
cheers
topher
Administrator
Serious forum addict
fully functioning
Re: Performance issue
22 August 2009, 22:58 »
is it just flat or is it misfiring?
J6BXR
23 August 2009, 00:15 »
just flat like having no turbo.
topher
Administrator
fully functioning
23 August 2009, 00:20 »
no engine light on i take it? probably won't be limp mode then unless someone has removed the engine management light (not unheard of)
jack the car up and stick your head under the drivers wing, find your intercooler and check neither of the hoses have popped off.. then follow the pipes back as far as you can and make sure its all connected tight.
navmk4gti
Forum addict
23 August 2009, 00:28 »
check it on vag com too see if any fault codes pop up
Website:
https://www.theonestopledshop.com/
jake
23 August 2009, 01:13 »
could possibly be a MAF sensor, if it feels like the power is cutting out, or boggy! very common problem, and does not bring engine lights up!!
J6BXR
Reply #6 on:
23 August 2009, 10:11 »
cheers guys
redevo1
Here all the time
golt gti 1.8t AGU
Reply #7 on:
23 August 2009, 11:49 »
To be honnest how long have you had it? Mine used to drive like that before the remap, starts to pull then just flat after 3500-4000rpm.
God I've got a golf I'm getting old!Full Recaro leather with arse waming seats, the reason for buying a Golf!Spec: R tech remap:Eibach Fr+Rr ARB:Powerflex ARB bushes:Forge BOF DV:Silicone TIP:Induction kit:Jamex suspension:312mm big brake setup: EBC pads F+R:Vr6/g60 clutch:5mm-fr+15mm-rr spacers: Anni front & rear Valances & Anni rear roof spoiler: Silicone hose boost/Breather kit.
J6BXR
Reply #8 on:
23 August 2009, 22:29 »
Topher sounds like you are on the mark (again)
Jubilee clip on bottom intercooler pipe not there , no idea why some brown residue on the pipe corrosion of clip perhaps? , haven't tested car yet so fingers crossed.
cheers
John
topher
Administrator
fully functioning
Reply #9 on:
23 August 2009, 22:33 »
residue means it's been blowing.. so thats probably the issue, opening up once the boost builds and p!ssing the air out. That would be the first one i've come across where the clip is actually missing though!
Golf mk4
Wazzzer
Performance issue
