Author Topic: Carbs or Injection?  (Read 2215 times)
Offline kraM
  • It's not the speed, it's the sudden stops...
Carbs or Injection?
« on: 21 August 2009, 09:30 »
Hi
I have been given a KR lump (yahoo)
with no inlet/exhaust/injection system (boo)
Is it worth the twin 40's route, or the find a big inlet manifold & injection system?
Is there a real power advantage to for a 4 branch manifold?  (I only ask this as I know that the standard cast iron 16v one works very well)
I know that a special bodge job is required with out one, but the cost difference is very tempting.
Thank you
kraM
It's not the speed... it's the sudden stops...
Re: Carbs or Injection?
« Reply #1 on: 21 August 2009, 11:10 »
I'm running a totally std kr lump on std managment in my MK1 and I'm loving it, plenty of power and reliable.  My downpipe was a modified item to mate up to the std 16v manifold and mk1 exhaust, works alright!
all comes down to you really, what sort of money/effort are you willign to put in, and how bothered are you about fuel economy!
Offline kraM
« Reply #2 on: 21 August 2009, 11:30 »
Money = tight as ever
Fuel costs = my 1600 has always needed a fuel tanker in tow...
I know that the K-Jet system is about as good as a fuel injection system gets, with out all the morden day stuff [fit and forget stuff] (did the KR have a knock sensor?), are carbs that good, or do they go outa sync quickley?
kraM
« Reply #3 on: 21 August 2009, 11:56 »
kraM
I would run k-jets, carbs need looking after and yes they can go out of sync quickly.
« Reply #4 on: 21 August 2009, 12:09 »
no knock sensor on the kr, about as simple as it can get managment wise!  problem is most of it is different so you'll need to source quite a lot of bits to get it going. some of the mk1 gear can be used but its not ideal. though if its a 1600 the metering head apparently supplies a lot of fuel, so might be good enough for the 16v, but you'll probably need the proper 16v air flap as its a different profile to the 1600 one. of course all the pipe work and fuel lines all different lengths too etc
Offline kraM
« Reply #5 on: 22 August 2009, 21:19 »
If I can get my tow car back on the road, I may have found a complete front end write off MK2 valve, engine and running gear intact.  If so, anyone wanna baggsie anyparts I don't use?
I am keeping the rear disc/stub axel etc
The wiring loom/ecu/ignition thingy
Engine/'box
Injection system
Front brakes/suspension/body work etc will be up for grabs...
(If I get it, I'll stic it in the classifieds...)
kraM
« Reply #6 on: 24 August 2009, 10:30 »
what year is it? I know of someone who needs the chunky brake servo vac pipe :)
Offline kraM
« Reply #7 on: 26 August 2009, 14:36 »
The golf is a 1989 F, registared 01/06/1989
I have trailerd it home, stuck it on the drive and sat in once!
The O/S/F has been mullerd by a tree,
The interior is mint
The wheels are dirty but not kerbed (bottle top alloys)
It runs and has all the gears
Same colour glass all-round
Bodywork mint apart from the tree
If you need anything else, let me know.
If it is the right age, I'll have a look and see about the servo hose.
