Author Topic: FAO Topher  (Read 2946 times)
Offline Grand Master Patch
FAO Topher
« on: 20 August 2009, 21:38 »
What are your views on uprated intake manifolds? Is this something worth doing with a little ko3s,or is it only for the the big turbo guys?
http://abdracingwerks.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=ADIAR&Product_Code=70.INTM.1S
Offline topher
  • Administrator
  • fully functioning
Re: FAO Topher
« Reply #1 on: 20 August 2009, 21:40 »
i wouldn't bother unless you're aiming for the 300bhp mark... i would recommend an uprated intake manifold gasket though, helps keeps the temps down!
Offline tg1
Re: FAO Topher
« Reply #2 on: 20 August 2009, 21:47 »
there is a guy on one of the honda sites i frequent and he can make thicker hondata (google it) style gaskets. dunno how hard they are to get hold of for the 1.8t though or how much if he even does them
pretty sure it was under 50 quid though
Re: FAO Topher
« Reply #3 on: 20 August 2009, 21:47 »
Thanks,one more question,mister kit do anything?
Offline topher
  • Administrator
  • fully functioning
Re: FAO Topher
« Reply #4 on: 20 August 2009, 21:50 »
waiting to test that myself! some dyno logging with someone squirting a spray bottle at the IC is the plan... unfortunately my car is probably too low for the dyno now
Re: FAO Topher
« Reply #5 on: 20 August 2009, 22:04 »
The theory sounds like it should make a difference,but i guess we need to see some dyno logging to prove it.Wind it back up and give it a go.....
Offline topher
  • Administrator
  • fully functioning
Re: FAO Topher
« Reply #6 on: 20 August 2009, 22:06 »
when is yours booked in? i'll do it on yours :grin:
Re: FAO Topher
« Reply #7 on: 20 August 2009, 22:10 »
I should be down there the week after edition38 :wink:
Offline topher
  • Administrator
  • fully functioning
Re: FAO Topher
« Reply #8 on: 20 August 2009, 22:12 »
Sounds like a plan batman. If spray makes a difference to your fmic, it most certainly will with standard intercoolers.
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: FAO Topher
« Reply #9 on: 21 August 2009, 20:20 »
This is a similar upgrade as to what people used to do to there Calibra Turbo's, however looking at the ABD intake manifold you may come across similar issue's as the vauxhall boys.
Because the chamber is not tappered and just flat at the front the air distribution between cylinders will be uneven, the cylinder nearest the cambelt will intake the most air and the last cylinder near passenger side will have alot less air as it is not directed evenly. Yes power gains are possible but if your not putting enough air in the chamber to supply all cylinders evenly then the cylinders will be getting uneven combustion due to the air/fuel ratio.
there are many different designs out there rectangular, cylindrical and tappered, and i believe from alot of reading that an increase inlet manifold with a tappered design would work better as it helps direct air to the last cylinder.
