Author Topic: trying to change mk4 steering wheel any help would be very greatful  (Read 14872 times)
Offline GJSEB79
as above if some body could give a a run down on how easy this is and wether i need any special tools and how to i turn the airbag light off once in stalled or do i need a diffent boss cheers gordon got a mountney steering wheel an boss for a mk4 golf
Offline Rhyso
disconnect battery
make a cup of tea
start with wheel straight then turn to 90 degrees
on the back you'll feel a small hole - insert a small but strong screwdriver and lever the clip off - its a little tricky but its doable
turn wheel back through 180 degrees and repeat and remove airbag
no idea on the rest from there as i refitted an R32 wheel.  Would imagine you'd need some kind of resistor to fool the car into thinking the airbag is still connected
Offline GJSEB79
cheers for that i just hope somebody has put an after market one on here as you can buy one for airbag models which mine is
You will need a resistor on a aftermarket wheel, as it fools the car into thinking the airbag is still there.
Offline Grand Master Patch
Quick note that you don't need to disconnect the battery,just don't turn the ignition on when the airbag off,you won't get any airbag warning lights :wink:
Offline Rhyso
doesn't always work that way - i've removed a steering wheel without disconnecting the battery and no ignition on and the light came on  :undecided:
Offline GJSEB79
hi there cheers for that mate how will that work. let me get this right if i dont disconnect the battery and just dont turn ignition on this will make air bag lights stay off an never come on is this right or will i need some sort of resitor the steering boss i have bought said it was for an air bag model am i reading this right cheers gordon
Offline Rhyso
you'll still need the resistor to stop the airbag light coming on
i was on about when removing the steering wheel to swap it for another VW wheel i.e the R32 wheel
you got a link to the wheel you've bought?
No mate,as Rhyso said if your fitting an aftermarket steering wheel you will need a resistor to prevent the airbag warning light being lit.I was referring to fitting a vw steering wheel.
Offline tg1
please don't try and remove the airbag with the battery connected  :huh:
