Author Topic: Need new key - doors de-locked?  (Read 1978 times)
Offline Mr_Orange
« on: 20 August 2009, 19:18 »
Car has been de-locked by previous owner.  Can I get a new key sorted out and programmed / synchronised without the locks in the doors?  Aren't the locks used to program new keys?   :undecided:
Build thread clicky
Offline richw911
Offline Mr_Orange
Re: Need new key - doors de-locked?
« Reply #2 on: 20 August 2009, 19:27 »
http://www.golfgtiforum.co.uk/index.php?topic=111526.0
Read that.  I have been searching the arse off this subject!   :nerd:
Is that a yes?
I'm sure I read the drivers door lock is required and you have the original key in the ignition and brainless key in the door or something like that?
If I can do this without and just need to find someone with the software, then great as I've eyed up the correct key unit at VAGproducts!
« Last Edit: 04 September 2009, 08:16 by Mr_Orange »
Build thread clicky
Offline richw911
« Reply #3 on: 20 August 2009, 19:35 »
Is that a yes?
I'm sure I read the drivers door lock is required and you have the brainless key in the ignition and unlock at the door or something like that?
If I can do this without and just need to be-friend someone with the software, then great as I've eyed up the correct key unit at VAGproducts!
You can code the remote with Vag Com you need Vag Tacho and the SKC for the immobilizer coding tho  :wink:
http://uk-mkivs.net/forums/t/17868.aspx
Offline Mr_Orange
« Reply #4 on: 21 August 2009, 15:05 »
Cool, thanks!
Can Vag-tacho retrieve the secure key code or is that a VW thing?
Build thread clicky
Offline Rhyso
« Reply #5 on: 21 August 2009, 15:06 »
Cool, thanks!
hit and miss sadly  :sad:
Offline Mr_Orange
« Reply #6 on: 25 August 2009, 17:12 »
Local VW just quoted £45 to program a new key.
I phoned Timpsons who will be cutting it and asked them about coding, they weren't sure if they could "clone" it?
How likely is it I'm wasting my time arranging a VAGtacho session?
When I get the key, should I just go to VW?   :undecided:
« Last Edit: 26 August 2009, 16:56 by Mr_Orange »
Build thread clicky
Offline old_n07
« Reply #7 on: 26 August 2009, 08:19 »
Get in touch with R44MS_K he will be able to code the key in for you :afro: , he is based east London way IIRC
Neil
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline Mr_Orange
« Reply #8 on: 26 August 2009, 16:56 »
Neil
Aint he got ties with the VAGproducts company?
Build thread clicky
Offline old_n07
« Reply #9 on: 26 August 2009, 18:08 »
Neil
 :wink: :wink: :lipsrsealed:
