Author Topic: Front strut  (Read 2993 times)
gtigolfthree
Front strut
« on: 20 August 2009, 11:24 »
Noticed this morning that the n/s struut is sitting up at the top compared to the other one. Any ideas?
Re: Front strut
« Reply #1 on: 20 August 2009, 11:24 »
Your top mount has failed, replace the pair asap.
gtigolfthree
Re: Front strut
« Reply #2 on: 20 August 2009, 12:06 »
Whats involved in changing these?
Re: Front strut
« Reply #3 on: 20 August 2009, 12:34 »
You will need to remove the front shocks, compress the spring and replace as required.
Offline Horney
Re: Front strut
« Reply #4 on: 20 August 2009, 13:03 »
Bit of a faff but the parts are only about £20.
nick
gtigolfthree
Re: Front strut
« Reply #5 on: 20 August 2009, 13:29 »
Bummer I was hoping I could just take that nut off the top and just replace the rubber. Does that mean I will need to get the camber reset?
Offline Horney
Re: Front strut
« Reply #6 on: 20 August 2009, 13:34 »
You probably should do but I just mark up where the stut was bolted to the hub and make sure when I put it all back together that it lines up in the same place.
Nick
Re: Front strut
« Reply #7 on: 20 August 2009, 14:01 »
You will need to compress the spring before removing the top nut.
gtigolfthree
Re: Front strut
« Reply #8 on: 20 August 2009, 14:11 »
Could I fit the new top mounts to these and just swap them over?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160356446721&ssPageName=STRK:MEWAX:IT
Re: Front strut
« Reply #9 on: 20 August 2009, 15:21 »
Yes but you still need the top spring plate which is missing plus they look in very poor state.
