Author Topic: Child lock switch  (Read 952 times)
Offline matt_s
Child lock switch
« on: 19 August 2009, 13:03 »
Basically one of my rear doors has child lock on permanently. Actually on the frame of the door there is a little black dial that you put your car key into and turn it to switch the child lock off and on. No matter which position i have this dial set to the child lock is always on. Every time i have someone in the back i have to let them out! Its starting to get annoying.
Was wondering if I remove the door card would I be able to get to the rear of this dial to see if anything has snapped?! Has anyone had this problem before? Or know if it would be a simple fix?
Also is it easy enough to remove the door card? Never done it before  :grin:
Thanks.
