Author Topic: filler/fibre glass  (Read 1668 times)
Offline bratty
filler/fibre glass
« on: 19 August 2009, 11:10 »
i wanna smooth my wings on me project where the old trim strips were, im not a body work expert so what would be better to use filler of fibre glass if so some1 recommend a make :)
Quote from: Conker on April 28, 2009, 00:32
OMFG. Please tell me you were banging your willy on the keyboard and these were the random words that appeared.
Offline tshirt2k
  • Been there...Done that...
Re: filler/fibre glass
« Reply #1 on: 19 August 2009, 11:11 »
Would be better to weld a plate in the gap, then fill. Stops it cracking and falling out later.
Mk3 ABF 16VT Megasquirt V3
« Reply #2 on: 19 August 2009, 11:12 »
How deep, better to weld over and skim with filler, filler can crack and fall out.
Edit: too slow ^^^^
Offline bratty
« Reply #3 on: 19 August 2009, 11:13 »
yeh had though about that i know filler is prone to cracking is fibre glass the same as well?
and even after welding i'd still have to fill over it to smooth it?
ill take a pic its not that deep
« Reply #4 on: 19 August 2009, 11:15 »
yes if you weld it then you would need a skim of filler to smooth it over.
Offline bratty
« Reply #5 on: 19 August 2009, 11:26 »
not even sure if its worth welding a plate in its probably 2-3mm deep
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #6 on: 20 August 2009, 22:05 »
If you intend to fill that swage line, then you must seam weld the joint, as well as the holes! the original spot welds are not strong enough to be stable under the filler, it will crack! done properly it should be seam welded, then lead loaded then finished with filler
Thom
