Golf mk3
hardmonkeys
wheel bolts
Topic: wheel bolts (Read 2314 times)
andc1
wheel bolts
18 August 2009, 20:07 »
can anyone tell me what wheel bolts i have on my p plate anni? i need longer ones and i no where to get them from but there are so many different ones!
cheers all
Wayne
Sir Postalot
Re: wheel bolts
18 August 2009, 20:19 »
Factory alloys are rounded taper and m14 size.
andc1
Re: wheel bolts
18 August 2009, 20:20 »
i got standard bbs anni wheels
Wayne
Sir Postalot
Re: wheel bolts
18 August 2009, 20:21 »
Quote from: scoobygolf on 18 August 2009, 20:20
Yes they are from memory rounded taper and m14
andc1
Re: wheel bolts
18 August 2009, 20:28 »
cheers thanks alot
stu 88
Here all the time
Looking for a cheap set of 17's
Re: wheel bolts
18 August 2009, 20:49 »
Ive got a spare full set if you need some?
andc1
Re: wheel bolts
Reply #6 on:
18 August 2009, 20:50 »
longer ones?
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
Re: wheel bolts
Reply #7 on:
18 August 2009, 21:00 »
why do you need longer bolts??
andc1
Re: wheel bolts
Reply #8 on:
18 August 2009, 21:01 »
i have 20mm spacers to put on the back and the bolys and long enough
boneybradley
Forum Supporter
Back in a Mk3...
Re: wheel bolts
Reply #9 on:
18 August 2009, 21:06 »
I will advise if you run 20mm spacers with the o.e 215 tryes they will rub the arches! (more so if low!) I ran 16mm spacers and had to fit 195 tryes to stop rubbing! (that was at -40mm too)
Golf mk3
hardmonkeys
wheel bolts
