Author Topic: Spark Plugs  (Read 3641 times)
Offline Dalo Harkin
Spark Plugs
« on: 18 August 2009, 18:01 »
I have searched before Rhyso shouts  :smug:
So in the service section it says NGK and everywhere else people put Bosch Super 4's - which super 4's are recommended found some FR78 on ebay - will they do ?
W reg (unsure of engine code, must find that out  :smiley:)
thanks all
gtigolfthree
Re: Spark Plugs
« Reply #1 on: 18 August 2009, 18:40 »
In absence of the engine code you will at least need the engine type.
Offline Dalo Harkin
Re: Spark Plugs
« Reply #2 on: 18 August 2009, 22:06 »
ah yes that would help  :laugh:
1.8T on a W reg
Offline Devilz
  • Cruisin is not a crime
Re: Spark Plugs
« Reply #3 on: 18 August 2009, 22:17 »
1.8T on a W reg
it must be AGU then, if you want bosch super 4, goto halfords, you can get them for £20. I think you need 510 but you can check in their as well
Offline Grand Master Patch
Re: Spark Plugs
« Reply #4 on: 18 August 2009, 22:19 »
Offline Dalo Harkin
Re: Spark Plugs
« Reply #5 on: 18 August 2009, 23:53 »
1.8T on a W reg
Nah I am pretty sure there is a Z in my engine code  :undecided:
Offline Dalo Harkin
Re: Spark Plugs
« Reply #6 on: 19 August 2009, 00:04 »
Offline Dalo Harkin
Re: Spark Plugs
« Reply #7 on: 19 August 2009, 12:23 »
Anyone - if they are wrong - I need to get the right ones before weekend
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Spark Plugs
« Reply #8 on: 19 August 2009, 13:48 »
1.8T on a W reg
Why must it, when ARZ's & even some AUM's were out on a 'W'?!
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Re: Spark Plugs
« Reply #9 on: 19 August 2009, 13:50 »
Will these do the job people http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=200367350145&ssPageName=STRK:MEWNX:IT
That ad states that those plugs fit all 1.8T's, but I'm sure there were 2 different part no.'s in the Halfords book, when I was buying mine.  :undecided:
